611 Posted June 26, 2012 Share Posted June 26, 2012 (edited) Just putting the new clutch in (9" one) and the bolts I had from the 2.0l clutch cover don't seem man enough. Does anyone know if you can get ARP ones for the cover? The flywheel is off a monza but the same bolt size as a 2.0l Any help would be great. Andy Edited June 26, 2012 by 611 Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted June 27, 2012 Share Posted June 27, 2012 not sure if ARP do these, but check their web site to be sure, they have a good online list, better if you know the thread type size and pitch. I would go to an engineering supply shop and buy high tensile cap screws myself, get the highest tensile available in that size, will be heaps cheaper and just as strong as the rivets in the actual clutch cover (if not stronger) Quote Link to comment Share on other sites More sharing options...
611 Posted June 27, 2012 Author Share Posted June 27, 2012 Hey thanks for the info, i wasn't sure if high tensile would be ok or not! I will see if i can find an engineering place near me or look online. Andy Quote Link to comment Share on other sites More sharing options...
andyc Posted June 27, 2012 Share Posted June 27, 2012 Hi Andy Use the normal bolts form the 2.0 as they are the same as the 3.0, just make sure the spring washers are good Cheers Andy Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted June 27, 2012 Share Posted June 27, 2012 Andy Just replace them with std m8 cap head bolts, should be 12.9 stamped on the head, plenty strong enough! Chris Quote Link to comment Share on other sites More sharing options...
611 Posted June 27, 2012 Author Share Posted June 27, 2012 Hey Andy I think it was the spring washers that were causing the problem as on two of them the washer started to splay out! The hard part now is getting them out as the bolt heads don't seem that strong and the corners round easily if your not careful :-) and i think your right with the cap head bolts Chris, i think i should have got those first! Thanks Andy Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted June 27, 2012 Share Posted June 27, 2012 (edited) Andy Just replace them with std m8 cap head bolts, should be 12.9 stamped on the head, plenty strong enough! Chris yeah I agree with Chris this is what I was meaning, 12.9 is the tensile rating so that's mega. spring washers too. get a blow torch on the old ones, give them some heat and they will come out sweet as... Edited June 27, 2012 by opelmantagsi Quote Link to comment Share on other sites More sharing options...
611 Posted June 27, 2012 Author Share Posted June 27, 2012 Is this the sort of thing i need? http://www.fix8.co.uk/products/Fasteners/Socket+Cap+Screws/Socket+Cap+Screw+12.9+H%2FT+S%2FC/M8+x+20+Socket+Cap+Screw+High+Tensile/4229866618 Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted June 27, 2012 Share Posted June 27, 2012 that's them, just need to be sure the thread and length is identical to what your replacing. you will also want to put some blue loctite on the threads and torque them correctly Quote Link to comment Share on other sites More sharing options...
CalCol Posted June 28, 2012 Share Posted June 28, 2012 I've got grade 12.9 bolts on my 3.6 Monza along with grade 10.9 split washers (they didn't come in grade 12.9). Didn't get any nasty splaying when I put it together and it's holding so far. :-) Should definitely use blue Locktite, as you say. Cheers, Nick Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted June 28, 2012 Share Posted June 28, 2012 awesome, comments from the UK, NZ & The USA gotta love the internet Quote Link to comment Share on other sites More sharing options...
611 Posted June 28, 2012 Author Share Posted June 28, 2012 Its a great thing and google is even better, where would we be without it :-) Thanks for all the info guy's, i think i can get them from the local fastener place, so will be popping over next week. Then its pop the gearbox apart for a quick check to make sure its all ok and then that back in and then i can start to finish the motor build. Im sure i will have a few more questions before its running :-) Thanks Andy Quote Link to comment Share on other sites More sharing options...
