Shug Posted July 23, 2012 Posted July 23, 2012 Just fitting the loom to my manta (conversion from carbs) and want to make sure its plugged in correctly! Only identifier on each plug I can see is 41, 42, 43 and 44. So, which end of the engine do I start from? Quote
moodoo Posted July 23, 2012 Posted July 23, 2012 Doesn't matter...it's not sequential injection, so they're all firing at once anyway, the injector circuit is actually branched from a common point (I made my own injection loom last Winter!). Quote
mantadoc Posted July 23, 2012 Posted July 23, 2012 Moodoo is correct, they fire half the fuel required for each cylinder, to all cylinders on each revolution. 3 & 4 will be on the loom nearest the bulkhead, 1 & 2 will be nearer the thermostat housing connections. If oyu are lucky it will still say Zyl 1 etc on the black sleeving Quote
