opelmantagsi Posted January 21, 2013 Share Posted January 21, 2013 I am probably one of MANY looking for these. they are on e-bay Germany, just wondering if anyone knows of anyone else that sells them for less than an arm and a leg? http://www.ebay.de/itm/Scheinwerferringe-Set-fur-vier-IRMSCHER-Doppelscheinwerfer-Manta-B-GSI-/370741390754?pt=DE_Autoteile&hash=item5651e8ada2#ht_3675wt_1140 Link to comment Share on other sites More sharing options...
lepo5 Posted January 22, 2013 Share Posted January 22, 2013 How much of them do you need Derek? Link to comment Share on other sites More sharing options...
opelmantagsi Posted January 22, 2013 Author Share Posted January 22, 2013 (edited) Would be 4 but not sure how they will fit with the cibie mounting rings I have Edited January 22, 2013 by opelmantagsi Link to comment Share on other sites More sharing options...
robah Posted January 22, 2013 Share Posted January 22, 2013 How much of them do you need Derek? Would be 4 but not sure how they will fit with the cibie mounting rings I have I would be interested if they fit. My light rings are cracked and held together with plastic putty 1 Link to comment Share on other sites More sharing options...
novacabrio Posted January 24, 2013 Share Posted January 24, 2013 I've bought a set of these recently, although they are from a different seller. They aren't the best quality, but they will/do work from what I can see as they are an identical copy of the originals. The negatives I'd say (if they are the same ones I've purchased) are that the outer ring isn't a snug fit on the inner (back) ring, and the plastic outer ring isn't as high gloss finish as the originals but I think I'll plastic prime mine and have them painted..... 1 Link to comment Share on other sites More sharing options...
opelmantagsi Posted January 24, 2013 Author Share Posted January 24, 2013 ^^ that's interesting, thanks for sharing Link to comment Share on other sites More sharing options...
robah Posted January 25, 2013 Share Posted January 25, 2013 I have just took the plunge and bought some from the above site. (nearly £90.00 inc P&P) I will let you know what they are like when they turn up. It is one of the things that is holding me up. 1 Link to comment Share on other sites More sharing options...
robah Posted February 1, 2013 Share Posted February 1, 2013 Received headlight rings today. As you can see not the best quality, but I hope they are fit for purpose. I will look at them better when I try and fit them, I will keep you posted. 1 Link to comment Share on other sites More sharing options...
novacabrio Posted February 1, 2013 Share Posted February 1, 2013 You need some m4 stainless bolts 40mm long I think and then some m4 nylon wing nuts all available on eBay, I'm working on where to get springs from Link to comment Share on other sites More sharing options...
shaggy Posted February 10, 2013 Share Posted February 10, 2013 Derek if you get them from someone get them to send them to me and I will add to the parcel. 1 Link to comment Share on other sites More sharing options...
opelmantagsi Posted February 10, 2013 Author Share Posted February 10, 2013 (edited) yeah I need to work out if they will fit with the morette mounting rings I think the morette rings are the second generation mounting method Edited February 10, 2013 by opelmantagsi Link to comment Share on other sites More sharing options...
