Mototechnics Posted March 9, 2013 Share Posted March 9, 2013 (edited) My Rear Stabiliser (that's what Haynes calls it) is different from what is shown in the Haynes Manual. The pictures below show the bushes/brackets on each end. I'm assuming as usual Haynes don't cover every change to the car very well. I cannot see how to get them off (without hacking them to bits) to replace them, if indeed you can. Any help/advice much appreciated. Cheers, Mark Edited March 9, 2013 by Mototechnics Quote Link to comment Share on other sites More sharing options...
Shug Posted March 9, 2013 Share Posted March 9, 2013 They are awkward, but might come off with some twisting. They are the same bushes as a calibra 4x4 rear antiroll bar which are still available from vauxhall so I wouldnt worry if you destroy the rubber in the removal process. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted March 10, 2013 Share Posted March 10, 2013 as far as i know they hare are just tightly pressed/pushed onto the ends of the roll bar.you may have to cut them or they may just knock off Quote Link to comment Share on other sites More sharing options...
Mototechnics Posted March 10, 2013 Author Share Posted March 10, 2013 They are awkward, but might come off with some twisting. They are the same bushes as a calibra 4x4 rear antiroll bar which are still available from vauxhall so I wouldnt worry if you destroy the rubber in the removal process. Hi Shug Don't suppose you have a Part No. ? Quote Link to comment Share on other sites More sharing options...
Shug Posted March 10, 2013 Share Posted March 10, 2013 Unfortunately not, but I can tell you they were £2.50 each in 2010. Quote Link to comment Share on other sites More sharing options...
tom child Posted May 19, 2013 Share Posted May 19, 2013 I've just done mine got superflex bushes if you still need part numbers let me know ill find them out Quote Link to comment Share on other sites More sharing options...
