mantasrme Posted March 22, 2013 Share Posted March 22, 2013 This is big brake kit for the front of the manta (or chevette/ kadett etc) It consists of a set of new 284mm sierra cosworth brake discs modified to fit the manta along with a pair of early calibra Turbo calipers. The discs have been to the engineer and had the centre bore enlarged and 4 new mounting holes drilled, they share the same offset as the manta so do not require a spacer. Calipers are secondhand but have free moving pistons, dust seals in good condition and free bleed nipples. Thay come with carrier brackets and banjo bolts. You will need at least 15" wheels to fit these brakes and depending how agressivley you drive and what rear brakes you're running you might need to look at the brake ballance With standard rear drums these brakes are a little too powerfull and can result in the fronts locking with spirited driving, a rear disc conversion and correct grade of pads sorts this. Or a bias pedal box can also be used. I'm after £160 for the setup and £10 shipping to mainland uk Or you can collect from Harrogate North Yorkshire PM me or e-mail David(AT)Mantasport.co.uk Pictures to follow Quote Link to comment Share on other sites More sharing options...
rutts Posted March 22, 2013 Share Posted March 22, 2013 this is a good front set up i had them on my hatch with a monza master cylinder as dave says put good pads in and they will stop very well just dont jump on them too hard in wet. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted May 17, 2013 Author Share Posted May 17, 2013 Quick bump for these and I'll do them for £150 posted for the next week as I could do with the cash to buy something. Quote Link to comment Share on other sites More sharing options...
manta88 Posted June 10, 2013 Share Posted June 10, 2013 Hi ,would you consider selling the calipers only ? Mick. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted June 10, 2013 Author Share Posted June 10, 2013 Sorry the kit has sold. Quote Link to comment Share on other sites More sharing options...
