Rear Springs
tnk228r
do it a coil at a time as a coil makes a big difference. i usually put wire from chassis to spring cup so spring cannot fall out when jacking up after wards. or buy shorter shocks koni do shorter ones.
Cutting off a coil does work as far as lowering but will change the way the spring works and will chew up the rubber top hat.
I had some made for mine by these guys. http://www.springcoil.co.uk/suspension_springs.html
sent them the ones i had and they made lower ones but adjusted it so the sping was still the same stiffness.
Andy
