Wheel Nuts (And Sockets)
rutthenut
Having some difficulty with my nuts ...
Using either a 22mm socket, or a cross-type wheel brace, I find that the socket doesn't quite fit into the recess in the GT/E alloy wheels. Some nuts are easy enough but others near impossible to tighten properly.
What's the solution?
Smaller nuts, longer nuts, or slimmer socket?
Don't have a standard Manra toolkit for comparison.
Thoughts, suggestions?
Never had a problem myself, but 22mm doesn't sound right. Thought they were 19mm nuts?
Ah, so my nuts are too big? ;-)
Will do a search but anyone know off-hand what the stud diameter/thread is on the Manta?
Edited to Add:
Opel GT forum describes those older items as M12 x 1.5 and M12 x 1.25 - not sure which is right.
Found an eBay listing for some alloy nuts to fit the Manta, which are M12 x 1.5, so is that the correct size?
Those happen to be 17mm nuts, in alloy, fwiw.
Edited by rutthenut
I agree with spiney the head of the bolt is 19mm, not sure of thread pitch, but wouldn't fancy alloy wheels either way.
Alloy wheels, or alloy wheel nuts?
I don't want lightweight alloy nuts - prefer simple steel ones (don't even car for chrome) and better still if open rather than closed.
This is on a rally car, so robust fittings more of a preference to shiny or lightweight parts...
Thanks for confirmation - will just order some new wheel nuts, M12 x 1.5mm, with 19mm head, so expect normal wheelbrace/socket to fit without contact with alloy wheel centres. Do not like the idea of my nuts coming off if not tightened properly!
Thanks. Further confirmation of the right parts.
I tend to use Demon Thieves or JJC for various bits, though have used Rally Design before.
Ordered mine from DT as I needed some other motorsport parts from them. Also get 10% discount there :-)
Cheers all
