mantaboy89 Posted June 6, 2013 Share Posted June 6, 2013 Have pulled the engine out of an sri. Before I scrap the car just wanted to know if I removed everything I needed. Pulled the engine, loom and ecu. Airbox is out so are thr intake pipes and also the lamba sensor. Are there any other sensors or anything I need to remove? Any help appreciated. Josh Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted June 6, 2013 Share Posted June 6, 2013 its pretty well covered here http://www.opelmanta16v.4mg.com/ Quote Link to comment Share on other sites More sharing options...
16vGraham Posted June 30, 2013 Share Posted June 30, 2013 dont forget to cut the lambda sensor socket out of the old exhaust. You will need it to mount the sensor onto the mantas exhaust system. Quote Link to comment Share on other sites More sharing options...
dynamytedan Posted July 1, 2013 Share Posted July 1, 2013 front calipers ? radiator fan ? Quote Link to comment Share on other sites More sharing options...
