Sutty2006 Posted July 8, 2013 Share Posted July 8, 2013 Just got the XE running. Only issue is the idle sits at 2000rpm. Is this down to an air leak? Brake servo or inlet manifold? New inlet gasket was fitted on installation of manifold. Any ideas? Quote Link to comment Share on other sites More sharing options...
andyc Posted July 9, 2013 Share Posted July 9, 2013 Sounds like an air leak. Get it running then go around all the joints with some brake cleaner, if there is a leak the cleaner will be sucked in and the engine note will drop Cheers Andy Quote Link to comment Share on other sites More sharing options...
rutts Posted July 9, 2013 Share Posted July 9, 2013 spray some carb cleaner down the idle valve inlet also. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 9, 2013 Author Share Posted July 9, 2013 Icv and knock sensor were plugged in the wrong holes! Quote Link to comment Share on other sites More sharing options...
