dog321fish Posted November 4, 2013 Share Posted November 4, 2013 (edited) Hi looking for some assistance please. 1983 1.8s Berlinetta. No known problem before parking up. car has been parked on drive for 3 weeks, so put battery on charge overnight. Engine turns on key, have spark but not getting fuel, put new "old stock" fuel pump on and still the same. Also tried "jump starting" it, but no go.. blown fuel pipe back to tank with footpump and can hear bubbles. sucked tube till fuel appeared and re-connected to pump. Also put 3 cans a fresh fuel in tank. What do people suggest I try next please ? Is there a way to prime the mechanical pump ? Cheers Dave Edited November 4, 2013 by dog321fish Quote Link to comment Share on other sites More sharing options...
pat Posted November 4, 2013 Share Posted November 4, 2013 does it try and run with a little fuel poured into the carb? or just do the same , could be a stuck carb float not allowing fuel into the carb Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 4, 2013 Author Share Posted November 4, 2013 Thanks Pat yes, it tried to start when i trickled petrol direct into the carb. Fitted another "new old stock" pump and replaced flexi pipe from the "hard" pipe to the pump as it was perished. Running fine now. Thanks again Cheers Dave Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted November 4, 2013 Share Posted November 4, 2013 this is an old 1.8 problem, fuel will evaporate from the float chamber when it has stood for a while and even run back down the fuel pipe so the fuel pump cavitates. I got fed up with going through the recharging of the system every time i left my 1.8 for a while so now i have fitted an electric fuel pump, it's a facet, a very small cube like affair that sits ontop of the tank strap near the tank sender unit,very neat, wired it in through the fog lamp fuse,which is an ignition swithched live. 2 Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 4, 2013 Author Share Posted November 4, 2013 (edited) Thanks for the info Mantaman is this in addition to the mechanical pump ? Is this the pump ? :http://www.ebay.co.uk/itm/Facet-electric-fuel-pump-/171094911374?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d60d298e Cheers Dave Edited November 4, 2013 by dog321fish Quote Link to comment Share on other sites More sharing options...
garymanc Posted November 4, 2013 Share Posted November 4, 2013 how about a non return valve http://www.ebay.co.uk/bhp/fuel-non-return-valve 1 Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 5, 2013 Author Share Posted November 5, 2013 (edited) Thanks Garymanc Seems like a good idea and a lot cheaper than an electric pump, has anyone tried it ? Cheers Dave Edited November 5, 2013 by dog321fish Quote Link to comment Share on other sites More sharing options...
garymanc Posted November 5, 2013 Share Posted November 5, 2013 worked okay for me ages ago was on a diesel van though Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 5, 2013 Author Share Posted November 5, 2013 OK thanks, I assume you fitted it at the tank end of the pipe ? Cheers Dave Quote Link to comment Share on other sites More sharing options...
garymanc Posted November 5, 2013 Share Posted November 5, 2013 was fitted in the engine bay Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 5, 2013 Author Share Posted November 5, 2013 OK, thanks Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted November 6, 2013 Share Posted November 6, 2013 yes thats the pump Dave, fitted next to the tank outlet, sitting neatly ontop of the tank strap, it bypasses the original fuel pump, but i have left that in for the sake of original appaerance and if i desired i could return it to original condition in an hour or so. Took the Manta out Sunday and it hadn't moved in nearly a month, normally this would entail taking the air filter off, undoing the fuel pipes and charging the carb and fuel line with petrol poured in through a small funnel. what a performance, now I turn the ignition key, a short while of fuel pump ticking and it fires up striaght away = result! 1 Quote Link to comment Share on other sites More sharing options...
dog321fish Posted November 6, 2013 Author Share Posted November 6, 2013 Thanks for that Mantaman Quote Link to comment Share on other sites More sharing options...
