Manta Aerial?
coupeking
Does anyone have any ideas where I can purchase a black wing aerial for an exclusive??
My original has deceased.
There are one or two I've found on a couple of sites but the underhang need to be at least 34cm (as there's a support bracket that the mast base fit into connected to the body). The ones I've seen have a 26cm underhang.
Most are chrome but this really needs to be black.
Edited by coupeking
I used a golf mk2 one as the top bit is narrow enough to fit on top the manta wing. You can get away without the support if you are OK with that.
Try a search on ebay with black mast to see what you can find, also try German ebay too
  • 7 months later...
