mikemanta Posted April 12, 2014 Share Posted April 12, 2014 I have a straight six 24v senator engine and a manta gte 5 speed box, I also have a redrilled Monza flywheel to fit the 24v engine so I can use the bigger clutch but which plate is best to use? the Monza one has different splines to a gte box any help would be great Quote Link to comment Share on other sites More sharing options...
andyc Posted April 12, 2014 Share Posted April 12, 2014 I'm using a Monza Clutch on the 2.4 and that fits the standard five speed box without a problem, sure it's a Monza Plate? Andy Quote Link to comment Share on other sites More sharing options...
mikemanta Posted April 12, 2014 Author Share Posted April 12, 2014 yes I have a Monza box getrag 265 and the splines are a lot bigger and there are less of them than the manta box I didn't know if there was two different clutches same size plate but different amount of splines Quote Link to comment Share on other sites More sharing options...
andyc Posted April 12, 2014 Share Posted April 12, 2014 I'll have a look at mine tomorrow, take some pices for you if thats any help Andy Quote Link to comment Share on other sites More sharing options...
mikemanta Posted April 13, 2014 Author Share Posted April 13, 2014 that would be great Quote Link to comment Share on other sites More sharing options...
Alf Posted April 13, 2014 Share Posted April 13, 2014 yes I have a Monza box getrag 265 and the splines are a lot bigger and there are less of them than the manta box I didn't know if there was two different clutches same size plate but different amount of splines Hi, I'm no expert on Monza's but I do know there are two different sets of splines, one has ten the other 22 (I think, been a long time since I played with one!!) I think the ten splined one is from the early Monza and the 22 from later cars, there is also a difference in clutch plate diameters, the GSE has the larger clutch at 240mm, the 3.0E and lesser model Monza's have a smaller one, 233mm I think, again from memory!! The ten spline 240mm clutch plate is really hard to get these days, the smaller one is readily available through Ebay and I believe they all fit the flywheel OK? If it helps, there are certain Volvo 260's which use the same driven plate and also some of the early 'E' Type jaguars, although they charge the earth for those!! I do have a manual Monza I will be breaking later this year if you get stuck but I doubt I'll find the time to start on it until September?? Cheers, Alf. 1 Quote Link to comment Share on other sites More sharing options...
mikemanta Posted April 13, 2014 Author Share Posted April 13, 2014 that would make sense my box came out of a gse , so if I get the 233mm clutch will this fit the gte 240 box? Quote Link to comment Share on other sites More sharing options...
rutts Posted April 13, 2014 Share Posted April 13, 2014 (edited) ">http://http://s77.photobucket.com/user/ruttsphotos/media/samsung048_zpse4848158.jpg.html'> three types of input shaft splines on the 265 gearbox. course = bmw type clutch plate medium = opel fine = jaguar and ford fitting I used C+G clutches in leeds he will make anything you require, if you have a good centre with correct splines he will put the outer from what ever fits in the diameter range within a couple of mm. I had a ford centre ( jaguar 265) no springs in centre withfive ceramic pads for £80. bargain Edited April 13, 2014 by rutts Quote Link to comment Share on other sites More sharing options...
andyc Posted April 13, 2014 Share Posted April 13, 2014 This is the one we are using Hope this helps Andy Quote Link to comment Share on other sites More sharing options...
611 Posted April 13, 2014 Share Posted April 13, 2014 Looks to be the same setup as im running Andy. Monza flywheel and the big clutch with the 5 speed gte box. Got my clutch plate from germany off ebay.de Hope this helps as well. Quote Link to comment Share on other sites More sharing options...
mikemanta Posted April 14, 2014 Author Share Posted April 14, 2014 thanks for all the replies do you have a part number Andy? Quote Link to comment Share on other sites More sharing options...
andyc Posted April 14, 2014 Share Posted April 14, 2014 I had ind the a look at the box but there was a dirty great big duck tape over the lable which just ripped, i might be able to find the GM number Cheers Andy Quote Link to comment Share on other sites More sharing options...
611 Posted April 20, 2014 Share Posted April 20, 2014 Andy C Let me know if you cant find the number and i will see if i can look out any info as i usually try to keep the numbers somewhere!! Andy Quote Link to comment Share on other sites More sharing options...
mikemanta Posted April 21, 2014 Author Share Posted April 21, 2014 been digging around seems I bought a clutch plate a while ago stuck it in my parts and its what I need result, found a new cover too so even better according to the info on the box its for a commodore gse or heavy duty record and its a 9 inch or 228 mm and 14 splines so hope this will work , would like to say thank you to all that helped that's why this club is great. Quote Link to comment Share on other sites More sharing options...
611 Posted April 21, 2014 Share Posted April 21, 2014 Your right, it makes all our lives easier :-) and saves hours googleing!! Andy Quote Link to comment Share on other sites More sharing options...
