devilwoo Posted May 14, 2014 Share Posted May 14, 2014 Looking to replace the injection system with 45's, does anyone have an inlet manifold that will accommodate? Regards, Link to comment Share on other sites More sharing options...
rutts Posted May 14, 2014 Share Posted May 14, 2014 you need the short ones like irmscher and other makes as you will find they touch the master cylinder. pm lepo5 he has a few sets of manifolds at good prices. 1 Link to comment Share on other sites More sharing options...
devilwoo Posted May 14, 2014 Author Share Posted May 14, 2014 Thanks! Link to comment Share on other sites More sharing options...
rayman Posted May 14, 2014 Share Posted May 14, 2014 One just come on ebay 271490597379 Link to comment Share on other sites More sharing options...
devilwoo Posted May 14, 2014 Author Share Posted May 14, 2014 Is that the correct one? (Short) Link to comment Share on other sites More sharing options...
rutts Posted May 14, 2014 Share Posted May 14, 2014 (edited) looks long to me. check on german ebay usually a few on bit more expensive but do the job correctly. 261466364666 Edited May 14, 2014 by rutts Link to comment Share on other sites More sharing options...
lamchop77 Posted May 14, 2014 Share Posted May 14, 2014 Move the servo to the front of the inner wing behind the headlight no probs with clearance then. Come on rutts use ur noggin!!!!! Link to comment Share on other sites More sharing options...
spiney_norman Posted May 14, 2014 Share Posted May 14, 2014 Still don't like the idea of the extending rod connecting pedal to servo coming straight at your chest in a crash. Surely worth spending the extra few quid on a shorter manifold? Link to comment Share on other sites More sharing options...
devilwoo Posted May 17, 2014 Author Share Posted May 17, 2014 Bump, I'm still searching. A full set up would be nice? Anyone? Link to comment Share on other sites More sharing options...
devilwoo Posted May 21, 2014 Author Share Posted May 21, 2014 Bump, still looking for a manifold. Link to comment Share on other sites More sharing options...
rutts Posted May 21, 2014 Share Posted May 21, 2014 are the ones on german ebay too expensive I put item number on above. good cheaper option is a single 48 dhla on manifold. ring re performance in bury manchester they had one in new old stock around £120 Link to comment Share on other sites More sharing options...
devilwoo Posted May 21, 2014 Author Share Posted May 21, 2014 Hi Rutts, Ken @ RE Performance is actually the one who is fitting the 234 Cam, lsd, fitting the Webers and new manifold if I can find one and setting up on the RR. I can find loads of new inlets suitable for it but they are expensive... Looks like I'll have to bite the bullet and get one. Which are better, the two separate inlets or the one piece? Mike. Link to comment Share on other sites More sharing options...
lepo5 Posted May 21, 2014 Share Posted May 21, 2014 are the ones on german ebay too expensive I put item number on above. good cheaper option is a single 48 dhla on manifold. ring re performance in bury manchester they had one in new old stock around £120 I offered the only set for 45's that I had for £80 but that seems to be too dear for him Link to comment Share on other sites More sharing options...
devilwoo Posted May 21, 2014 Author Share Posted May 21, 2014 That's not a fair statement, Lepo5. You said they were the long type that foul the servo. I never mentioned anything about them being too dear. If your manifold is the same as what the other dealers are selling then it's the obvious choice for me to take it. 1 Link to comment Share on other sites More sharing options...
lepo5 Posted May 21, 2014 Share Posted May 21, 2014 I never did hear back from you to say its not the right one etc as it was a good few days ago ,but when your post above states that your still looking for a manifold I could only assume that the price was a bit too strong for you and you also had mentioned that loads of new inlets were suitable for it but they are expensive... I took it that the price was an issue. Link to comment Share on other sites More sharing options...
devilwoo Posted May 22, 2014 Author Share Posted May 22, 2014 The price isn't an issue, I'm just getting conflicting info from various people and dealers about the correct size. My feeling is that everyone has the same size manifold, that being long like the unit you have. Sending you a pm Link to comment Share on other sites More sharing options...
