Denis K Posted August 12, 2014 Share Posted August 12, 2014 I have been getting different info on this. Some people use atf and others 75w90. What is the actual correct oil or these boxes? Cheers Quote Link to comment Share on other sites More sharing options...
rutts Posted August 12, 2014 Share Posted August 12, 2014 Vauxhall oil is correct or I used Valvoline semi synthetic 75/85w. Castrol synthetic available at Halfords. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted August 12, 2014 Share Posted August 12, 2014 As Andy says there is a specific vauxhall oil for the getrag boxes. Don't have the part number to hand but it's on this forum somewhere. If your just topping up, and you're sure the box is still on vaux oil thats the way to go as it doesn't like mixing with other types of oil. If you're draining it and starting from fresh then you can use any good quality semi or fully synthetic oil of the right grade. The box will then change as smoothly as when it was new. Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted August 13, 2014 Share Posted August 13, 2014 Some people do use ATF as well, it'll do the job but would require changing more frequently (than every 20 years with the usual! :-D ) Personally, I use the castrol 75w/90, the only reason you won't find that grade/type specified is that gear/axle oil wasn't available as a synthetic multigrade when the cars were contemporary. Top tips, loosen the filler plug before draining (incase you can't budge it), feed a metre of garden hose from the engine bay to the filler hole, there's even a loop on the box that you can cable tie the pipe to. It makes it easy to fill from standing up and not having to squeeze the bottle of oil into the box via difficult access. Quote Link to comment Share on other sites More sharing options...
