Lowering Steering Rack
CRAZYDAVE
1) which sump / engine?
2) speak to Mantaray if you must, his way is the only one I have seen that would maintain geometry
3) take a leaf out of the book of the guys that make TR8s out of TR7s, the budget version, without TR8 bonnet, they lower the subframe
Hi Mantadoc
Thanks i'll send him a pm
Cheers
Dave
Shouldn't need to on a B series as the engine sits so far back, a series is a different matter
Andy
Hi Andy
Thanks i'll see how much clearance there is. I was thinking i would need to lower the rack based on a conversation i had at a show with someone about a Gold B series gte running a 3.0 which was featured in total vauxhall. i was told the rack is moved down in that car for clearance.
Cheers
Dave
From the only V6 conversion i've seen, Bronze Coupe from Scotland, sorry can't remember who it was, the engine sits so far back you could almost call it a mid mounted engine.
Interested to know how you get on as i'm collecting the parts to V6 mine, one day
Cheers
Andy
Cheers
Andy
Thats the car. I'm in the same boat at the moment collecting all the parts i need but thought i would ask some sound advice beforehand :)
Cheers
Dave
Mine will be a little different and will need a one off sump made as i plan to have the motor mounted half way over the cross member.
What induction system are you looking at?
Andy
I'm going to buy a whole Vectra and use as many of the standard parts as possible.
Cheers
Dave
You'll be better of trying to find and early cavailer or calibra as you'll have a steel sump which you can mod and the electrics are more or less the same as a redtop conversion, plug and play
Andy
Brilliant cheers for the heads up :thumbup
Cheer the ID code on the ECU if you go for a Cavailer /Calibra. Your looking for either PN or TX on the big sticker, if its HE or KC then it will have the immobilizer with is just another problem to over come. Beware though these early ECUs are hard to find
Andy
Definately would take advice on using early cav or cally, much simpler wiring, done my old mk3 astra van in a weekend using a cavalier loom and ecu.
Andy
Thanks Andy and Paul great help :thumbup
