Front Subfamily Mounting Bolts
Redrobie
Hi, I have had to remove the large bolts through my swan necks and had to resort to cutting them off. I have found replacement bushes but not the bolts themselves. Does anyone have a pair available, new or used?
Cheers, Bob.
I normally just use standard high tensile bolts with nylock nuts, can't remember the size/length of top of my head but just a bit longer than the standard ones as the nylock nut is thicker.
Available from any good nut/bolt hardware place
hi i have a brand new pair, i had to do same as you last year to repair my swan necks and bought extra bolts let us know if you want or not will add photos after.
You can have them for £5 Is it two you need?
