dan_123 Posted March 27, 2015 Share Posted March 27, 2015 First of all i apologise as i know I've posted before about it... I was wondering if anyone had used anything else for the seal between each of the four lamps and the housing? Im sure I've read people buying rubber from woolies and was wondering if so, which one seemed to work the best? Many thanks! ……really need this part! Dan Quote Link to comment Share on other sites More sharing options...
Kenny400 Posted March 27, 2015 Share Posted March 27, 2015 Vauxhall green parts seem to have them new http://www.vauxhallgreenparts.co.uk/Manta.html 1 Quote Link to comment Share on other sites More sharing options...
Ems Posted March 27, 2015 Share Posted March 27, 2015 The ones I used to have had some sort of foam between the lights and housings. Quote Link to comment Share on other sites More sharing options...
dan_123 Posted March 30, 2015 Author Share Posted March 30, 2015 Thanks very much ill check this out! Quote Link to comment Share on other sites More sharing options...
Daza Posted April 4, 2015 Share Posted April 4, 2015 I emailed Keith today,,, Its the rubber between the rim and the bodywork which they have,,, no the foam rubber between the lap unit and the rim You can imagine my disappointment! D Quote Link to comment Share on other sites More sharing options...
garymanc Posted April 4, 2015 Share Posted April 4, 2015 do you mean the rubber around the light if so make your own with cycle inner tube Quote Link to comment Share on other sites More sharing options...
Jenson Posted April 4, 2015 Share Posted April 4, 2015 Hi do you have any pictures of the rubber round the lights and how you did this with cycle inner tube many thanks martin. Quote Link to comment Share on other sites More sharing options...
garymanc Posted April 4, 2015 Share Posted April 4, 2015 just take the lamp out and cut a piece of inner tube to suit and then leave a small overlap and glue together think i used evo stick , i found it best when a stretched it a little as it was not tight enough when cut to size Quote Link to comment Share on other sites More sharing options...
dan_123 Posted April 7, 2015 Author Share Posted April 7, 2015 Brilliant i will do this thanks very much for the help. car looks good by the way!!! 1 Quote Link to comment Share on other sites More sharing options...
