Daza Posted April 2, 2015 Share Posted April 2, 2015 (edited) Sorry, I know this may be a silly question,,,, But, does anyone have a any Irmscher Headlight adjusters? any at all please? Or Does anyone know of a good modification? Thanks, Darren Edited April 2, 2015 by Daza Link to comment Share on other sites More sharing options...
lepo5 Posted April 2, 2015 Share Posted April 2, 2015 how much do you need? Link to comment Share on other sites More sharing options...
Daza Posted April 2, 2015 Author Share Posted April 2, 2015 Dont tell me you have some? I have 5 so need 7 I guess...if anyone can help? Cheers D Link to comment Share on other sites More sharing options...
lepo5 Posted April 2, 2015 Share Posted April 2, 2015 sorry, I'm not able to help this time. Link to comment Share on other sites More sharing options...
Daza Posted April 2, 2015 Author Share Posted April 2, 2015 Thats ok... the reply got my hopes up... probably have to engineer my way out of this one! Link to comment Share on other sites More sharing options...
Kevin Abbott Posted April 3, 2015 Share Posted April 3, 2015 I'm doing a full write up on a conversion I can do. When I get time I will upload the pics to photobucket and list the parts required. I can't get to the pc at the mo and tablets are useless for building a topic. Link to comment Share on other sites More sharing options...
Kevin Abbott Posted April 4, 2015 Share Posted April 4, 2015 5 Link to comment Share on other sites More sharing options...
Daza Posted April 4, 2015 Author Share Posted April 4, 2015 Hi kevin I await in anticipation.... Just noticed that Vauxhall green parts may have the rubber seals Cheers D Link to comment Share on other sites More sharing options...
mantadoc Posted April 4, 2015 Share Posted April 4, 2015 It all depends whether Irmscher Hella (older stuff) Irmscher Cibie (Basically just Bolts) Irmscher Lucas (bolts with hooks on) Link to comment Share on other sites More sharing options...
Daza Posted April 4, 2015 Author Share Posted April 4, 2015 (edited) Hey kev... What you think of my first attempt? Components from Halfords and Wicks! Where did you get your springs from? Cheers D Edited April 4, 2015 by Daza Link to comment Share on other sites More sharing options...
Kevin Abbott Posted April 5, 2015 Share Posted April 5, 2015 (edited) Looks good Daz. You don't have a lot of space to work with and that looks wide. Does it fit in the housing without showing at the sides too? Springs I got from eBay. 7.1mm OD and a wire diameter of .8 mm should give an ID of 5.5 to fit over the M5 bolt The standard spring length is 25mm but the top one may need making shorter as it's tight because the nut adds about 5mm to the distance between housing and light unit Edited April 5, 2015 by Kevin Abbott Link to comment Share on other sites More sharing options...
Daza Posted April 6, 2015 Author Share Posted April 6, 2015 I' seen nylon pan head screws on ebay, or even a stainless pan head screw,,. that would reduce any overhang that you get with a bolt. Also seen rod hangers on RS Components, but not sure if they go small enough yet. Link to comment Share on other sites More sharing options...
