madmantamik Posted November 18, 2015 Share Posted November 18, 2015 Hi, all question 1- is it possible to install a 16v engine without moving the servo? question 2 if the servo needs to be moved, is it best to use a remote servo or just twin master cylinders question 3 internal pedal box or external pedal box? any thoughts please. Thanks. Quote Link to comment Share on other sites More sharing options...
garymanc Posted November 18, 2015 Share Posted November 18, 2015 you don't need to move servo to fit a c20xe engine Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted November 18, 2015 Share Posted November 18, 2015 It is even possible to put quad Webers on a XE and not move the servo The carbs can only have short trumpets and 'sock' filters, the brake fluid reservoir needs moving ( easy to do using a Renault Megane remote reservoir ) and it helps to a recess in the front of the servo itself ( seperate the halfs, weld in the altered section, re-crimp the halfs back together ) Quote Link to comment Share on other sites More sharing options...
mantasrme Posted November 18, 2015 Share Posted November 18, 2015 As Gary says, if you are using the standard injection then no it doesn't need moving/modifying. With carbs it might, depending on the carb and manifold length/angle. DCOE's will prob need something like Ian suggests, Bike carbs might not (again depending on manifold length) Quote Link to comment Share on other sites More sharing options...
