kikobot Posted February 15, 2016 Author Share Posted February 15, 2016 thx to all I saw that FWD engines have the oilsump at the rear of the engine, is it a good idea to start with a FWD sump, oil pickup pipe and baffle plate ? If i raise the heigth of the engine, would it fit without cutting the sump? Quote Link to comment Share on other sites More sharing options...
Snowy Posted February 15, 2016 Share Posted February 15, 2016 (edited) 4 hours ago, kikobot said: thx to all I saw that FWD engines have the oilsump at the rear of the engine, is it a good idea to start with a FWD sump, oil pickup pipe and baffle plate ? If i raise the heigth of the engine, would it fit without cutting the sump? The FWD sump has the bowl at the back but the RWD sump has it at the front. See below. RWD sump: http://www.ebay.co.uk/itm/VAUXHALL-CARLTON-2-0-SUMP-IDEAL-XE-REAR-WHEEL-DRIVE-CONVERSION-OR-OTHER-/191630746197?hash=item2c9e152255:g:yLEAAOSwyQtVo8Dt Or the FWD sump: http://www.ebay.co.uk/itm/170653211755?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT But what suits your application. Where is your crossmember? Edited February 15, 2016 by Snowy Quote Link to comment Share on other sites More sharing options...
kikobot Posted February 15, 2016 Author Share Posted February 15, 2016 here is the same car like mine: Here is my crossmember after painting: a c20ne sump modified for a rekord c done by a guy who made a c20ne swap on its car, he tells its a fwd sump : better sized Quote Link to comment Share on other sites More sharing options...
kikobot Posted February 15, 2016 Author Share Posted February 15, 2016 Quote Link to comment Share on other sites More sharing options...
kikobot Posted February 21, 2016 Author Share Posted February 21, 2016 hello, do you think this sump would fit on a x20xev or a c20ne ? http://www.fsrs-partswebshop.nl/en/pan-assy-oil-opel-ascona-c-corsa-a-kadett-e-vectr.html Quote Link to comment Share on other sites More sharing options...
Snowy Posted February 21, 2016 Share Posted February 21, 2016 14 minutes ago, kikobot said: hello, do you think this sump would fit on a x20xev or a c20ne ? http://www.fsrs-partswebshop.nl/en/pan-assy-oil-opel-ascona-c-corsa-a-kadett-e-vectr.html I'm not certain. But I would have thought it would have been listed with the engine codes 18SV or 20NE etc if it would. Quote Link to comment Share on other sites More sharing options...
kikobot Posted February 21, 2016 Author Share Posted February 21, 2016 Snowy,on the link you gave me for the fwd sump ,it was fittable with c16nz2 , in the link i have just posted it will fit with a c16nz, so i tought it was fitable on a c20ne or a x20xev Quote Link to comment Share on other sites More sharing options...
Snowy Posted February 21, 2016 Share Posted February 21, 2016 2 hours ago, kikobot said: Snowy,on the link you gave me for the fwd sump ,it was fittable with c16nz2 , in the link i have just posted it will fit with a c16nz, so i tought it was fitable on a c20ne or a x20xev Ask the seller. I only know sumps that fit the 20NE, 20SE, 18S etc will fit. Quote Link to comment Share on other sites More sharing options...
kikobot Posted February 21, 2016 Author Share Posted February 21, 2016 (edited) yes, i was thinking to do that, if anybody else have an experience with this combination, you are welcome thx snowy for your interest Edited February 21, 2016 by kikobot Quote Link to comment Share on other sites More sharing options...
