Irmsher quad headlights bolt position
Dom400
I am going to replace the quads on my car with a proper set from irmscher, does anyone know the correct position for the 2 bolt holes that need to be drilled into the nose cone?
I was hoping to get some dimensions to create a template, rather than drilling a couple of holes and hope for the best!
Thanks!
Dom
Centre of the hole radiator side: 2 cm to the vertical pillar radiator, 10 cm to the bottom.
Centre of the hole wing side: 1.5 cm to the inner-wing(excactly on the seam), 10 cm to the bottom.
