halley cockburn Posted May 5, 2016 Share Posted May 5, 2016 Hi just wondered when my slid my sunroof to open and close it rubs on the top part of the sunroof scraping the paint, is there any adjustment so the sunroof slides lower to open and close thanks Quote Link to comment Share on other sites More sharing options...
Rapierdave Posted May 6, 2016 Share Posted May 6, 2016 This usually is an indication that the sunroof cassette is rusting underneath the roof skin, the rust pushes a bar down onto the top of the sliding sunroof. 1 Quote Link to comment Share on other sites More sharing options...
halley cockburn Posted May 9, 2016 Author Share Posted May 9, 2016 Hi again, I am gettting the car painted i about 4 weeks and did not want to scratch the sunroof when sliding it back is there anything i can do to make it slide back without touching thanks Quote Link to comment Share on other sites More sharing options...
Chris M Posted May 13, 2016 Share Posted May 13, 2016 Try pushing up onto headlining from inside the car . You may well feel/hear a crumbling which will indicate that the tray is starting to go. Has the roof started to show corrosion on the top side? i did exactly the same with mine, no corrosion on the outer roof skin but feeling the headlining inside all was not well. I took the required steps to rectify, you might want to do the same before spending your hard earned on a paint job. good luck. Quote Link to comment Share on other sites More sharing options...
halley cockburn Posted May 16, 2016 Author Share Posted May 16, 2016 Have you got a tel no to discuss as will have to try something to improve as meant to go to painters in just over 2 week or you can get me on 07863 `179 535 thanks halley Quote Link to comment Share on other sites More sharing options...
