part number wanted for oil pressure transducer
gtwist
14 hours ago, H-400 said:
This is the sender with the 2 connections (warning light/oil pressure)
12 52 550
08949332
Grts!
Hi Herman thanks for your reply ... is this part number for a left hand drive Manta as i see your from Belgium I've been given another number GM08975471 who has stated its for a right hand drive Manta.
Thanks Geoff
9 hours ago, Julian said:
Spiney _Norman is the man you need to contact, he works in a store that sells them.
Hi Julian thanks for your reply ... do you have a contact number for "Spiney-Norman?
thanks Geoff
01269591128  That is the shop number for B& R MOTOR FACTORS in Ammanford.
I will not give his mobile number as I do not have his permission to do so.
Anyway he is one of our members, you can PM him.
Edited by Julian
Hi Geoff
thought they were the same? The location of the sender is at the right side of the engine,
under the exhaust manifold somewere beside the 4th cylinder?
It is an ordinary VDO sender you can order at any shop, just make sure the screw-thread fits.
Grts!
1 hour ago, H-400 said:
Hi Geoff
Grts!
thanks Herman I had mine moved to the front of the engine for easy access
thanks Julian for the information most grateful
The reason of the other partnr. is maybe cause all the post '82 GT/E's and GSI's (left hand driven) have that stupid
econometer instead of the oil pressure indicator. That sender is only for the warning light...
So I could buy such a oil pressure gauge of the same design as a GSI thanks an other forum- member.
Been in touch with B & R motor factors they have them in shop @ £39.80 + £6 postage prob VAT on top of that also ... thanks again Julian .... Les87GTE ... Steve did you get my PM to you>
Geoff
