Frontera 2.4
2 hours ago, Irmscher Man said:
104,000 miles and running badly.
Sounds like it probably needs a bottom end rebuild so I wouldn't take this on lightly!
Although the crankshaft rods and pistons are all you need to build your 2l block into a 2.4.
Use the injection system too and head.
Its the Crankshaft Rod and Pistons that are the problem with this engine. As you say, the block is basically the same old CIH block, although the Fronty version will have the 2.4 casting mark. IF rebuilding, it is probably worth looking into replacement rods and pistons, the VX design was pretty terrible.
