sound insulation required
cam.in.head
hi to all. am looking for the thick rubber / foam sound deadener that lives under the bonnet above the pedal box ( normal rhd car)in uncracked condition if there is such an item left nowadays.
they  usually look fine (as mine did) untill you try to remove them then they just split everywhere!
many thanks
Think this is a dragons den topic,  How many will you sell? Every manta owner in the world times two, as they will buy a spare.
Any ideas for making new alternative? Anyone? Im thinking expanding foam, imagine the mess!
Seriously, im thinking tiger seal, stanley blades, and rubber black paint,  to restore, or sheets of 3mm rubber, tiger seal, and lots of work. Minus the GM stamp to remake!
What does it do, insulate to keep heat in? Or is to keep moisture out? Maybe both, is it sound deading?
If you have the original cracked and in pieces do the following.
Put all pieces in order from one side using some kind of metal clips to hold them.
Spray many layers of rubber undercoat(not with wax  ) so to create a new skin for it.
Spray both sides of the rubber.
Many layers and let each layer to dry really well . In the end you will have a NEW reinforced sound deadening ...
