hoobby Posted April 17, 2020 Share Posted April 17, 2020 So I've managed to bugger up the hot /cold wire doubled it over before it came out the arm tried to straighten it up but has fatigued and has lost its stiffness If I'm right 1mm piano wire and cable nipple (no pun intended) would fix this?. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 17, 2020 Share Posted April 17, 2020 Put into a clamp, tighten it up twisting and then heat it up and fob in some low temp solder Quote Link to comment Share on other sites More sharing options...
hoobby Posted April 18, 2020 Author Share Posted April 18, 2020 Panic over managed to get the inner wire out and straighten it all out much easier sitting at a table with tea now works smoothly and now stays on another cheap fix . 1 Quote Link to comment Share on other sites More sharing options...
