hoobby Posted June 21, 2020 Share Posted June 21, 2020 According to Haynes 42 + - 3psi (3 + - 0.2 bar) I got 30psi or 2 bar and lost half of that after turning off for 3 mins. Could assume it's the pump but what further tests can I do to confirm were the problem is?. Quote Link to comment Share on other sites More sharing options...
H-400 Posted June 21, 2020 Share Posted June 21, 2020 Hi Hooby, the Haynes manual is about the L-jetronic. That injection has got a feul pressure regulator of 3 bar, but the LE-jetronic is 2,5 bar (36 psi) but both need to be tested with the rubber vacuum line off. So check what injection you'v got, the L has got grey injectors and the LE yellow ones. Grts; Herman 2 Quote Link to comment Share on other sites More sharing options...
hoobby Posted June 21, 2020 Author Share Posted June 21, 2020 Thanks Herman it's a le-jetronic (yellow caps) got 36psi at idle with vac hose off so pressure is good. Quote Link to comment Share on other sites More sharing options...
