paulmanta Posted December 12, 2020 Share Posted December 12, 2020 Hi. I need to try and get hold of some scrap b/gte/1800 wiring looms. Preferable with the rear light plugs and as many other bits as possible, I don't mind if they are cut or incomplete, it would be nice if they had the fuse box. I don't need the separate injection sub loom, I have got loads of those it seems. I'm trying to make a new look up for my V8 and also for my coupe project, both have been bodged and have problems in different areas. My plan is to make two "new" standard looms up with a modified fuse box to take blade fuses instead of the plastic ones that melt and go open circuit. Happy to pay for the donor looms and post. Pm me! Link to comment Share on other sites More sharing options...
stumpy Posted December 13, 2020 Share Posted December 13, 2020 i used a led fusebox on one of my previous builds the wires are connected via a ring terminal and an m5 screw has 1 main power pole and the seperate earth outlets for each circuit makes it a lot easier Link to comment Share on other sites More sharing options...
MrCarlos Posted December 13, 2020 Share Posted December 13, 2020 I can do you a couple of looms paul - £20 each ? Both with fuse boxes Link to comment Share on other sites More sharing options...
paulmanta Posted December 13, 2020 Author Share Posted December 13, 2020 Done deal! Mint. Thanks. Link to comment Share on other sites More sharing options...
