TJ101 Posted January 29, 2021 Share Posted January 29, 2021 (edited) Afternoon,, Would anyone have, or know the whereabouts of a 84 GTE fuel tank and sender unit ?? ? Cant seam to add a reply, bar a EDT here,, Thanks Mike, but its for a hatch, so guess different ? Edited January 29, 2021 by TJ101 Link to comment Share on other sites More sharing options...
Mike. Posted January 29, 2021 Share Posted January 29, 2021 If it’s a coupe tank you require there is one for sale here on this link. 1 Link to comment Share on other sites More sharing options...
MrCarlos Posted January 29, 2021 Share Posted January 29, 2021 Manta gte hatchback Injection Fuel Tanks These are impossible to find in good condition used but dont panic - I have a solution ! This is a fully professionally reconditioned tank Pressure tested and all leaks identified All weak areas of metal removed , new metal welded in Breather pipe attachments all replaced with copper pipe Cleaned inside to remove all sludge, loose rust scale and stale fuel deposits Pressure tested at the end to confirm tank is now leak free Painted in black - would recommend a good coat of waxoyl when fitted £350 plus postage if required SUPPLIED ON AN EXCHANGE BASIS - I MUST HAVE YOUR OLD FUEL TANK OTHERWISE I CANT CONTINUE TO SUPPLY I do have this tank in hand so can supply immediately 07889 141818 Located Burnley, Lancashire 3 Link to comment Share on other sites More sharing options...
