Jonathan Pounsett Posted June 27, 2021 Share Posted June 27, 2021 Does anyone know what size the headlight fixing nuts are? Are there two nuts on each stud - one to hold the reflector to the plastic housing and one to hold the hole unit in the car? Thanks. Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted June 29, 2021 Author Share Posted June 29, 2021 Can anyone help with this? Quote Link to comment Share on other sites More sharing options...
Snowy Posted June 30, 2021 Share Posted June 30, 2021 8 hours ago, Jonathan Pounsett said: Can anyone help with this? Which type of lights are you struggling with? Quote Link to comment Share on other sites More sharing options...
IanMc Posted June 30, 2021 Share Posted June 30, 2021 On 27/06/2021 at 07:54, Jonathan Pounsett said: Does anyone know what size the headlight fixing nuts are? Are there two nuts on each stud - one to hold the reflector to the plastic housing and one to hold the hole unit in the car? Thanks. Yes, two nuts for each of the four studs as you describe. They need an 8 mm A/F socket to remove, so they must be M5 from that. I recall that they are a small, fine thread, so that also ties up with the M5 sizing. Hope that helps. 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted June 30, 2021 Author Share Posted June 30, 2021 3 hours ago, Snowy said: Which type of lights are you struggling with? Rectangular ones. Thanks. Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 5, 2021 Author Share Posted July 5, 2021 On 30/06/2021 at 07:38, IanMc said: Yes, two nuts for each of the four studs as you describe. They need an 8 mm A/F socket to remove, so they must be M5 from that. I recall that they are a small, fine thread, so that also ties up with the M5 sizing. Hope that helps. New stainless steel M5 flanged nyloc nuts arrived today. Perfect fit. Thanks @IanMc . 1 Quote Link to comment Share on other sites More sharing options...
