Skragmor Posted October 31, 2021 Share Posted October 31, 2021 (edited) Hi all, I have recently fitted individual throttle bodies to my XE so I have some spare parts to sell. All parts came off a working car which recently went to Hungary and back without missing a beat so the parts are in good working order. The doubles I have of parts have also been tested on the car prior to taking them off so all working too. I haven't put the price of postage on there in case someone wants to buy more than one thing, in which case I can combine the parts into one package. If you want to buy more than one thing or the whole lot I can do you a price. Parts can be collected from South London. Any questions, feel free to ask. ------------------------------------------------------------ All parts come from a dizzy type 20XE M2.5 Cone air filter with aluminium pipe and polyurethane hose This will fit to the airflow meter and bring the airfilter behind the headlight on a Manta B £15 I have 2 Bosch ignition coils £10 each Bosch Idle control valve £30. SOLD Irmscher powercap £75 Rubber that goes between power cap and MAF, bought brand new from LMFVauxhall 6 months ago £20 Bosch Air flow meter £20 for the one with the damaged grill and £25 for the one in better condition. 2x throttle body £50 each Reconditioned distributor, done 5000 miles since being reconditioned £80 I also have a 1.8 Manta distributor that has had the inside gutted out and the inside of an XE distributor fitted inside so it can be used to run an XE with injection when the distributor has been relocated to the front, like when running carbs. £80 Fuel rail with fuel pressure regulator removed with AN6 fittings £20 1 standard 20XE M2.5 ECU £50 1 chipped 20XE M2.5 ECU, the chip I bought is supposed to have Mathijssen Technics' map from opel-tuning.nl, rev limiter at 7300RMP £50 2x Bosch fuel pump relay, 1 is from an XE and other from a 20SEH but I believe they will both work the same £10 each. 1 SOLD 1 STILL AVAILABLE. 2x Distributor cap, 1 Bosch and one no-name £20 quid for the 2. Many thanks Edited November 20, 2021 by Skragmor Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted October 31, 2021 Share Posted October 31, 2021 Can I have the ICV and XE fuel pump relay please? Would you do both for £40 posted? 😁 Quote Link to comment Share on other sites More sharing options...
Skragmor Posted October 31, 2021 Author Share Posted October 31, 2021 2 hours ago, Sutty2006 said: Can I have the ICV and XE fuel pump relay please? Would you do both for £40 posted? 😁 Alright Steve, yeah that's fine I can do that. The XE one is the one with the bracket attached to the side. The ICV will come with the hoses you seen on the picture. PM me your details and we'll get it sorted. Cheers. Quote Link to comment Share on other sites More sharing options...
Manta hatch Posted November 1, 2021 Share Posted November 1, 2021 Il take both the coils if complete with amps on mounting plate cheers Quote Link to comment Share on other sites More sharing options...
Skragmor Posted November 1, 2021 Author Share Posted November 1, 2021 11 hours ago, Manta hatch said: Il take both the coils if complete with amps on mounting plate cheers Hi, Yeah both come exactly as in the picture with the amps on them. Pm me with your details. Cheers Quote Link to comment Share on other sites More sharing options...
nunziospike Posted March 3, 2023 Share Posted March 3, 2023 I know it's been a while but its the power cap still available? Quote Link to comment Share on other sites More sharing options...
Skragmor Posted March 12, 2023 Author Share Posted March 12, 2023 On 03/03/2023 at 20:11, nunziospike said: I know it's been a while but its the power cap still available? Hello mate, Yes it is still available, I've PMed you. Quote Link to comment Share on other sites More sharing options...
Pigeonrat Posted April 18, 2023 Share Posted April 18, 2023 Hi, On the offchance they are still available, I would be very interested in the ECU with the FP ident and the better of the two airflow meters please? If you could let me know that would be great, thanks... Quote Link to comment Share on other sites More sharing options...
