Jonathan Pounsett Posted July 26, 2022 Share Posted July 26, 2022 Help! My fuel lines were too close to the exhaust manifold and melted through. Luckily I spotted it straight away and shut it off before anything caught fire. I’ve rerouted the lines and put them in heat resistant sleeve but I think they are still getting dangerously hot. What are the best fuel lines that can resist extreme heat and how close can they be to the manifold? Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 26, 2022 Share Posted July 26, 2022 1 hour ago, Jonathan Pounsett said: Help! My fuel lines were too close to the exhaust manifold and melted through. Luckily I spotted it straight away and shut it off before anything caught fire. I’ve rerouted the lines and put them in heat resistant sleeve but I think they are still getting dangerously hot. What are the best fuel lines that can resist extreme heat and how close can they be to the manifold? Copper is absolute best (steel would be if you have tooling for it). is the routing right coming up the bulkhead wall for it to be getting so close? 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 26, 2022 Author Share Posted July 26, 2022 40 minutes ago, Jessopia74 said: Copper is absolute best (steel would be if you have tooling for it). is the routing right coming up the bulkhead wall for it to be getting so close? Yes. I’ll get a photo in the morning. 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 29, 2022 Author Share Posted July 29, 2022 I think I will bring the fuel lines up inside the wheel arch and enter the engine bay by the passenger side brake pipe. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 29, 2022 Share Posted July 29, 2022 (edited) Hmm, that’s wrong side?. All my cars have pipes other side mate, the GTE having it go all the way up the inner wheel arch and then through the wing (guessing for safety reasoning). Maybe that would best option in your case too. They are just holes with grommets in, as pictured. Edited July 29, 2022 by Jessopia74 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 29, 2022 Share Posted July 29, 2022 Is this a different engine? Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 29, 2022 Author Share Posted July 29, 2022 6 hours ago, Jessopia74 said: Hmm, that’s wrong side?. All my cars have pipes other side mate, the GTE having it go all the way up the inner wheel arch and then through the wing (guessing for safety reasoning). Maybe that would best option in your case too. They are just holes with grommets in, as pictured. That’s what I’m going for. Are there also holes through the jacking point? 3 hours ago, Sutty2006 said: Is this a different engine? My engine is different. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 29, 2022 Share Posted July 29, 2022 2 hours ago, Jonathan Pounsett said: That’s what I’m going for. Are there also holes through the jacking point? My engine is different. Yeah they run the pipes along the floor through jacking point. Just 16mm round hole with open grommets. 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 30, 2022 Share Posted July 30, 2022 What engine is it? Not caught up with the projects thread. Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 30, 2022 Author Share Posted July 30, 2022 33 minutes ago, Sutty2006 said: What engine is it? Not caught up with the projects thread. Rover V8 4.6 with Emerald ecu. 1 Quote Link to comment Share on other sites More sharing options...
