Greg w Posted September 9, 2023 Share Posted September 9, 2023 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 9, 2023 Share Posted September 9, 2023 (edited) Astra GTE, Cav SRI mk1 256mm vented . Much sought after Caliper . Use on Manta with Audi 80 (redrilled) disc. Edited September 9, 2023 by Jessopia74 1 Quote Link to comment Share on other sites More sharing options...
Greg w Posted September 29, 2023 Author Share Posted September 29, 2023 thanks before i try and clean them up i’ll see if new ones are available. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted September 29, 2023 Share Posted September 29, 2023 2 hours ago, Greg w said: thanks before i try and clean them up i’ll see if new ones are available. You can get recon calipers but you need to keep the carriers so clean them up well as they are not available new. What wheels are you aiming to put them under? They fit under some 13" rims but not all. So worth trying the calipers on the car before you get too far if you are set on a particular wheel. Also i have the modifed Audi discs you need in stock normally already done and ready to fit the manta. There's one set on the shelf currently. Quote Link to comment Share on other sites More sharing options...
Greg w Posted September 29, 2023 Author Share Posted September 29, 2023 thanks it already had this setup on roughly. i bought the car years ago from a family of the deceased who was building it, so it’s in many states of unknown mods i’m trying to work through. one thing i’ve noticed slight washer spacer between the mounting and callipers to centralise the carrier around the discs what are fitted. while this doesn’t seem a problem the bolts do need to be slightly longer, do you no what thread they are or even have an answer? Thanks 🙏 carriers to hub. sorry. the car is currently on 15” wheels but i fancy 14” mini lites. any advice on offset etc. Quote Link to comment Share on other sites More sharing options...
