john man Posted January 10 Share Posted January 10 Hi, I would say this has been asked numerous times. Is there any modification to the manta gearbox tunnel to fit the r25 gearbox. Or does the gear level hole need to be modified? Plan is to fit a c20xe also? Cheers John 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 11 Share Posted January 11 It’s a little tighter, but fits. The selector needs a slight mid to get into exact same position, but easy done with basic cutting/welding skills.And fabricate a mounting. From my memory it helps if you can drop engine a little too, think it’s escort mounts. If hydraulic slave used, needs a spacer inside box, they are about on the net still. Pics are my R28 mounted to SAABB234 lump, for mockup, but it’s an XE sump pan (for mk2 escort, but fits), but was mounted in XE at first. 2 Quote Link to comment Share on other sites More sharing options...
john man Posted January 11 Author Share Posted January 11 Thanks @Jessopia74 Much appreciate the response and the photos. Potentially picking up a box on Saturday, say its from a v6. 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 12 Share Posted January 12 V6 Omega? 😎 Jess, does Escort XE sump fit B234, no mods? Was R25 used for V6 What's was R28 used in? I have two V6s and a Rbox for free, must take a day and investigate. Quote Link to comment Share on other sites More sharing options...
john man Posted January 12 Author Share Posted January 12 Hi EVO03 @Jessopia74add details on the forum below on serial numbers fir the gearbox if any help. 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 13 Share Posted January 13 On 12/01/2024 at 10:15, ®evo03 said: V6 Omega? 😎 Jess, does Escort XE sump fit B234, no mods? Was R25 used for V6 What's was R28 used in? I have two V6s and a Rbox for free, must take a day and investigate. V6 can use both R25 and R28 depending on capacity. No the sump is not a direct fit mate, it is close enough to use as a starting point. Mine is a work in progress, but you would need a steel gasket profile for the SAAB bottom, think they are on eBay still along with the water outlet adapters etc Quote Link to comment Share on other sites More sharing options...
john man Posted January 13 Author Share Posted January 13 Hi @Jessopia74 Would you know what clutch kit combination is needed? Can I stick with the c20xe or do I need to get a omega disk with the c20xe pressure plate. Also the spacer needed for the slave cylinder do you know the size? This is my clutch on the engine, I presume this is a flat type, I hear people talk about. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 14 Share Posted January 14 You will need a flat type flywheel. https://www.ebay.co.uk/itm/285594003256 Clutch is for the early type 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 14 Share Posted January 14 Johnman, if you search Saab Turbo on here, think there was a few knocking about or engine code B234. 1 Quote Link to comment Share on other sites More sharing options...
john man Posted January 15 Author Share Posted January 15 Hi @Jessopia74 / @®evo03 Thanks for the info. @Jessopia74 when you say early type clutch, would it be somthing like this, an early type clutch kit for a C20Xe. I pressume these flat flywheels came in the early C20XE. https://www.aemotorsport.co.uk/shop/luk-3pc-clutch-kit-for-vauxhall-calibra-cavalier-c20xe-early-flat-type-flywheel/ Quote Link to comment Share on other sites More sharing options...
gt4_ade Posted January 20 Share Posted January 20 r25 box 2.5/6 v6, r28 box 3.0 r30 box 3.2 all boxes stamped as r25-28 pretty sure from memory you need an xe pressure plate with turbo friction plate 2 Quote Link to comment Share on other sites More sharing options...
gt4_ade Posted January 20 Share Posted January 20 imo the best box to use nowadays is the 5 speed bmw zf box given that omega boxes are getting harder to come by, one from a 330d is super strong and also fir into the tunnel without mods 3 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 20 Share Posted January 20 1 hour ago, gt4_ade said: imo the best box to use nowadays is the 5 speed bmw zf box given that omega boxes are getting harder to come by, one from a 330d is super strong and also fir into the tunnel without mods Any other mods needed? Slips on ? Front part of prop, is that it ? Are they cable or hydraulic? Quote Link to comment Share on other sites More sharing options...
gt4_ade Posted January 20 Share Posted January 20 1 hour ago, ®evo03 said: Any other mods needed? Slips on ? Front part of prop, is that it ? Are they cable or hydraulic? they bolt straight up to an xe bell housing using an adapter plate, front prop flange is the same as the omega i.e. 3 bolt. external hyd clutch slave. only bit thats a faff is the clutch as its duel mass however the xe and bmw flywheel bolt pattern is very similar so with some slugs made to offset the bmw holes the flywheel should also fit 2 Quote Link to comment Share on other sites More sharing options...
john man Posted January 20 Author Share Posted January 20 Thanks @gt4_ade for the info. Pick up a v6 omega box the other day. Sorted a flat fly wheel, just need to sort a clutch and the spacer for the slave cylinder. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 20 Share Posted January 20 1 hour ago, john man said: Thanks @gt4_ade for the info. Pick up a v6 omega box the other day. Sorted a flat fly wheel, just need to sort a clutch and the spacer for the slave cylinder. Good genuine R28 box that ‘HP’ code , nice and strong 💪 1 Quote Link to comment Share on other sites More sharing options...
gt4_ade Posted January 21 Share Posted January 21 7 hours ago, Jessopia74 said: Good genuine R28 box that ‘HP’ code , nice and strong 💪 hp box is the r30 omega box on the left 330d zf box on the right for anyone who is interested, input shaft on the bmw box makes the omega one look like a toy 1 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted January 21 Share Posted January 21 (edited) Sure that’s same input as 265 box. And yeah HP is R30 ofc. Edited January 21 by Jessopia74 Add picture Quote Link to comment Share on other sites More sharing options...
