JonnyD Posted March 18 Share Posted March 18 Hi all. My rear fog light (the hanging down off the bracket type) is not working. Wondering if you can help me source one of the relays as in the images attached. I believe this to be my rear fog light relay. All replacement three pin ones I can find are flashers and I don’t want my rear fog light on the dash or light to be flashing when I’m use. would this relay be put back or replaced by previous owner in error? any help appreciated Quote Link to comment Share on other sites More sharing options...
mantasrme Posted March 19 Share Posted March 19 Thats not a fog light relay, thats the door open buzzer on a later car from memory. The rear fog light doen't have a relay, just the switch in the dash. If its not working start with the bulb, then the earth connection at the lamp (some of them earth to the bumper bracket and that goes rusty over time). Then the switch and fuses. 1 Quote Link to comment Share on other sites More sharing options...
JonnyD Posted March 19 Author Share Posted March 19 Thanks for that information but would you know why that relay would be clicking multiple times when you press the fog light button? Quote Link to comment Share on other sites More sharing options...
mantasrme Posted March 20 Share Posted March 20 Does it buzz when you have the lights on and open the drivers door? Assuming your interior light actually comes on in that situation and the door sensor switch isn't iffy. Quote Link to comment Share on other sites More sharing options...
JonnyD Posted March 20 Author Share Posted March 20 Yes the buzzer goes off when the door is opened with the lights on. interior light works Quote Link to comment Share on other sites More sharing options...
JonnyD Posted March 20 Author Share Posted March 20 Do you have any other advice? Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted March 21 Share Posted March 21 ignoring the buzzer can you check that you have 12v at the centre contact or wire in the rear fog Quote Link to comment Share on other sites More sharing options...
JonnyD Posted March 21 Author Share Posted March 21 Definitely nothing at rear. Will check the relay centre contact this eve Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted March 21 Share Posted March 21 there is no relay. the power runs straight from the fog lamp switch above the light switch. if you have live to this ( with main lights on) then you should have a live coming out .the other wire is the earth for the switch illumination. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 18 Share Posted April 18 (edited) is it working now Edited April 18 by cam.in.head Quote Link to comment Share on other sites More sharing options...
JonnyD Posted April 18 Author Share Posted April 18 Yes. Thanks. Turns out it was always working but someone had wired it into the front fog light switch. the shame!!! Quote Link to comment Share on other sites More sharing options...
