1.8s timing adjustment
Simon Dobbo
Hi all
sorry if this has been covered before but can’t find much info.
for a novice
i found the notch on the pulley and the pointer - already painted white.
when using my mates strobe do I want them aligned with no adjustment on the strobe.
or do I dial in 10 degrees before tdc and set it there?
im unsure and the Haynes manual is confusing me - plus do I set differently for using unleaded fuel?
I am running it on premium E5
When I collected my Manta it was effectively running on three cylinders, caused by timing being out a tooth on the pulley!
I decided I best get the carb setup and timing at the same time. So mixture etc was aligned. I did time it with a stobe, to what I thought was right, but after gas analysis, it needed retiming. I thing 6 degrees, but don't have the printout to hand.
I had an old school krypton tune, by a mobile guy, but he won't leave Derby!
Edited by Opeloutbacks
So I set the gun at 7 degrees in the end
does that mean I now have 17 degrees BTDC -
guessing that too much but seems to run well and pull away with stalling more easily etc
possible small amount of pinking so will need to do again.
Without stalling I mean
Yes, you’re at 7+10deg. That is too much. At 15degrees I did see a tiny about of det(knock) starting at around 3500 in 4th with full load, so backed it if 1degree and it was gone. If I could re-jet the Varajet carb it would help no doubt, but could not be bothered as I do have a plan to fit a 1800E head/plenum with Megasquirt that I have , if I ever get around to it 🫣
Edited by Jessopia74
Thanks again
Mine has had the varijet replaced with a Webber.
Eventually i might look at an old fashioned Crypton tune or a day on rolling road to ensure all set to full pottential.
Im guessing to more advance the better to a point
8 minutes ago, Simon Dobbo said:
Thanks again
Yes, (mostly) run as much as you can without hitting detonation. When tuning ECU's we run at just on the limit mostly, but within 2-3degrees in the upper rev range does not make as much difference to engine pickup in
2 hours ago, Simon Dobbo said:
A few years ago I had my Spitfire set up at Denis Vesey following exhaust and cam changes etc.
Made such a difference - I might give them a call and just go for it to ensure im getting the most out of the Webber etc.
Definitely a good idea with the Webber 👍
Booked it
Dennis Vessey rolling road tune and carb re jet if needed - Tuesday 8th October
Was set up by home mechanic so Im sure it cant hurt and will make a difference
Ad ill have new oil seals and clutch in by then
1 hour ago, Simon Dobbo said:
Booked it
Excellent, be interesting to see what they come out with jets. Is it a 36/38 carb?
No it is a 32/34 DMTL according to the paperwork that’s in the glovebox.
a kit from Eurocarb - says it’s correctly jetted etc for the Manta 1.8s
but guess it’s been set up by ear - a proper tune can’t hurt
43 minutes ago, berni said:
There isnt any need to advance the 18s unless you want to create feuling issues and burn ya valves out quicker. May be nice off the lights now . Problems later 😏
Possibly - not my area - I’m a gas engineer 😂
I’m sure Dennis Vessey will advise etc
they were good before
im interested to see what the output on rolling road is before and after.
wondering whether to do anything with exhaust before hand
rear 2 boxes have been replaced with stainless so know idea if they are standard shape etc or not.
i will take a better look at the weekend.
is it a CAT at the front?
want to keep it standard as possible as it’s so original - but it has had carb change
would love exhaust to have bit more sound to it - it’s very quiet and tailpipe is tiny
It’s always been a bit boggy and spluttering occasionally
No CAT, it’s a resonator box. Is SS, then likely to be modern packed silencer design, so should be slightly less restrictive. Main restriction to most engines we use is what’s bolted to the engine. I.e inlet and exhaust manifolds, but they are still pretty good in comparison to older engine designs.
I would have liked to see a bigger crb tbh, but it’s still more reliable than an old Varajet
Yes
as I say it was done before me and that’s what Eurocarb/Dellorto recommend
i certainly don’t want to spend out to replace if I don’t have to.
receipt with it shows was £500 ish as a kit and was only early this year
Haynes manual seems to say 10 DBTDC but go for 7 DBTDC for unleaded
so that is an advance isn’t it
We will see what we can get with the expert and the equipment
Advance is more before TDC, so the pressure in cylinder is higher at point the piston reaches TDC. Ignore the manual, it was based on unleaded been lower RON then leaded, and the fact unleaded back then did not have any corn juice in it.
With what fuel your going to be running, I would definitely expect your tuner to set initial more advance than 10degrees, possibly around 14.
So the front pipe and box look original and a little like a cat but no sensors so thought not
rear 2 boxes replaced with stainless but look to be pretty standard not custom fitted
See what your man thinks when you get there I guess.
  • 4 weeks later...
  • 3 weeks later...
On 16/09/2024 at 19:30, Simon Dobbo said:
it is a 32/34 DMTL
This was certainly the standard, bolt on replacement offered for the 1.8 - I bought one for my first Manta.
It was smoother, had better throttle response and started better than with the Varajet, but it wasn't actually as quick, I imagine at least in part because ultimately the Varajet is bigger at 35/46.
Had it run up on a rolling road
was running very lean.
new main and idle jet and it’s much smoother and has more power.
just have the hot running issue to look at now.
been flat out for 2 weeks so not had chance.
was getting it on mates ramp today to check breathers and fuel pipe but he’s ill so lost the chance
getting worried now as taking it to NEC in less than 2 weeks.
Can recommend the Sportex exhaust, nice sound at idle and positively encourages a throttle blip when changing down.
