Drivers door (b1 coupe)
Sutty2006
Up for grabs today, a drivers door for B series.
minor surface corrosion starting at the bottom and at the rear edge, easily treated now and will be fine once treated. See pictures.
will need a few minor dents filling and painting but otherwise a good straight door. (Shame the passenger side wasn’t this good!)
no window or front window guide rail but I can put a broken guide in for now. Rear guide is mint, and in better condition than the one on my door. So grab it while you can.
can come with or without the trim, but if you’re fitting to a GTE or later model, the rivets will need removing.
external handle, latch and check strap and window regulator included.
collection from Stoke on Trent.
£100
Think the passengers door was LWB 🤣
Has anyone noticed some doors sit out at bottom edge on some cars.
Remember knocking both hinges forward 2mm on a shell years ago. Best fitting doors, and still pretty good. Also drilling hinges and doors adding slightly heavier door pins.
1 hour ago, ®evo03 said:
I would take that no probs, just the sea being a problem, Ireland. ☘️
I do t know of anyone heading over either, unless you do?
tbh if it doesn’t sell, I’ll just put it up the loft. It’s a good strong door and you never know what’s around the corner. Ideal if the car gets bumped.
