Craftycrofty Posted April 27, 2009 Share Posted April 27, 2009 Hi all, I have just bought a 1885 manta track/rally car and need some help. I would like to uprate the front discs and calipers and also add discs to the rear. The engine is a good runner but just had to order new water pump. All advice and comments welcome. Looking to have some fun with friends and family on track days and the ocasional rally. Kind Regards Martin Quote Link to comment Share on other sites More sharing options...
MudMax Posted April 27, 2009 Share Posted April 27, 2009 Hi all, I have just bought a 1885 manta track/rally car and need some help. I would like to uprate the front discs and calipers and also add discs to the rear. The engine is a good runner but just had to order new water pump. All advice and comments welcome. Looking to have some fun with friends and family on track days and the ocasional rally. Kind Regards Martin Hi Martin, for starters you want to think about what you want to use the car for. What i mean is simple, you can drive almost any car on a track day. If you want to rally, you may need to change a number of things on the car to meet FIA regs.e.g. Roll cage, fire safety,Tyres,Brakes,Engine, suspension mods, Belly plates etc. To make it simple Martin, I do build Race and Rally cars on a daily base. so if u want some help or advise u r welcome to contact me. Regards Andy Quote Link to comment Share on other sites More sharing options...
Shuviteer Posted April 27, 2009 Share Posted April 27, 2009 Thats true. I just intend using mine as an everyday run a round, with the occassional 1/4 mile blast down the strip, so with that I don't need to upgrade much. If you are using it for Rallies, then your suspension setup will be totally different to a track day set up.Unless you intend doing tarmac rallies. So as Andreas has said, you really need to decide which direction you want to go first,then look into the regs. Quote Link to comment Share on other sites More sharing options...
mantaman6 Posted April 28, 2009 Share Posted April 28, 2009 Hi all, I have just bought a 1885 manta track/rally car and need some help. I would like to uprate the front discs and calipers and also add discs to the rear. The engine is a good runner but just had to order new water pump. All advice and comments welcome. Looking to have some fun with friends and family on track days and the ocasional rally. Kind Regards Martin My Manta is in stock standard , mint condition . Bought in 76 , but actually a 1975 model , the last of the Manta A .s Not to sure how you would go about fitting discs on the rear . I.,ll be trying to download some pics of mine this weekend . If you go into www.youtube.comyou,l see a 1 min video of it [MANTAMAN 8] Stan from New Zealand Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted April 28, 2009 Author Share Posted April 28, 2009 Hi Andy, Thanks for the reply, the car has a roll cage and other bits,so i think some track days may be in order. I could send some photos if you would be prepared to have a quick look over them and comment. Once again many thanks I welcome the input of those who know lots more than me!!!! Kind Regards Martin Hi Martin, for starters you want to think about what you want to use the car for. What i mean is simple, you can drive almost any car on a track day. If you want to rally, you may need to change a number of things on the car to meet FIA regs.e.g. Roll cage, fire safety,Tyres,Brakes,Engine, suspension mods, Belly plates etc. To make it simple Martin, I do build Race and Rally cars on a daily base. so if u want some help or advise u r welcome to contact me. Regards Andy Thats true. I just intend using mine as an everyday run a round, with the occassional 1/4 mile blast down the strip, so with that I don't need to upgrade much. If you are using it for Rallies, then your suspension setup will be totally different to a track day set up.Unless you intend doing tarmac rallies. So as Andreas has said, you really need to decide which direction you want to go first,then look into the regs. Cheers , where can i find the right set of regs on the net?. I must sound daft but trust me easier to ask than search for ever!! Martin Quote Link to comment Share on other sites More sharing options...
Shuviteer Posted April 28, 2009 Share Posted April 28, 2009 Go to the RACMSA site and have a route around on there. Quote Link to comment Share on other sites More sharing options...
MudMax Posted April 28, 2009 Share Posted April 28, 2009 Hello Martin, if you wanted me to have a look at a number of images I gladly will. I would also suggest you get yourself an MSA book, which will give you an inside into rules and regs. Cheers Andy Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted January 2, 2010 Author Share Posted January 2, 2010 [Andy, All I have been very busy at work so only just got back to workshop and my Manta. I have removed the front suspension completely and will strip down and rebuild after refurbishing and painting. My question is this I think the car will be a track car so what do i need to replace and with what????? The springs and shocks are looking poor so will need advice on what to order here and also I want to upgrade discs and calipers so again what do i order and from where??? Many thanks for your advice in advance Martin Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 2, 2010 Share Posted January 2, 2010 Stitch weld ARB mounts to chassis rails. Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted January 2, 2010 Author Share Posted January 2, 2010 Stitch weld ARB mounts to chassis rails. Hi, Thanks for the reply. I am quite good with cars and mechanics of them but just need better instructions. Why stich weld ARB mounts and how does that help? ~sory but i only learn by asking please dont think i am being funny. I will always listen and learn from expereinced people. Kindest regards Martin Also Cross member has badly rusted on sring turrets in fact next to nothing left on driver side can you get spares or is it a new cross member....... Hello Martin, if you wanted me to have a look at a number of images I gladly will. I would also suggest you get yourself an MSA book, which will give you an inside into rules and regs. Cheers Andy Andy have some photos for you to have a chuckle over give me a shout Martin Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 2, 2010 Share Posted January 2, 2010 That was one of my three tasks to do on receipt of any standard Manta, otherwise they tear out when the cars are used enthusiastically. Depending on who built the car they are only on with four spot welds that fatigue. Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted January 2, 2010 Author Share Posted January 2, 2010 That was one of my three tasks to do on receipt of any standard Manta, otherwise they tear out when the cars are used enthusiastically. Depending on who built the car they are only on with four spot welds that fatigue. Consider that job done...... They will be welded tomorrow before i forget Cheers Martin need disc converstion on front and rear any suggestions??? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 2, 2010 Share Posted January 2, 2010 Steer clear of the Granada rear calipers. To be honest, seeing as the fronts do most of the braking and with one mod the rear handbrake becomes reliable and doesn't lock on if used heavily, such as auto tests, handbrake turns etc, I wouldn't have done mine as I inherited them with the car and have found the rear drums to be better and cheaper to maintain by far and less trouble. That said there are other calipers that can be used, and other disks instead of the cheap MK III Escort ones. What engine is in yours? Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted January 3, 2010 Author Share Posted January 3, 2010 Steer clear of the Granada rear calipers. To be honest, seeing as the fronts do most of the braking and with one mod the rear handbrake becomes reliable and doesn't lock on if used heavily, such as auto tests, handbrake turns etc, I wouldn't have done mine as I inherited them with the car and have found the rear drums to be better and cheaper to maintain by far and less trouble. That said there are other calipers that can be used, and other disks instead of the cheap MK III Escort ones. What engine is in yours? Mine is a Cavalier 2.0 not standard.... need to replace with in class or good fun motor!!!!! Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 3, 2010 Share Posted January 3, 2010 Mine is a Cavalier 2.0 not standard.... need to replace with in class or good fun motor!!!!! Bit vague. Do you mean Mk1 Cavalier / Manta CIH engine? (big old cast iron lump) Quote Link to comment Share on other sites More sharing options...
upk Posted January 3, 2010 Share Posted January 3, 2010 rear disc conversion:- vectra 1.7 turbo diesal 270mm solid disc 1995 - 2001 with zafira/astra rear caliper 2001- used escort caliper brackets welded onto rear axle ( bolt pitch n diameter for caliper is same) method:- bolt disc to axle hub ( ensure spigot sits correctly) bolt bracket to caliper, fit new set of pads, position caliper over disc and apply air pressure to caliper to clamp to disc weld in place. nb fit a bias valve so you can shift brake effort to front. Handbrake cable was custom made by RDB93, using an astra cable and original manta cable. for front you have many options, i used carlton disc and volvo 4 pot calipers on my A series but for the B i am going audi redrilled disc and 16v calipers. Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted January 3, 2010 Author Share Posted January 3, 2010 Bit vague. Do you mean Mk1 Cavalier / Manta CIH engine? (big old cast iron lump) big heavy 2ltr cast straight 4 with timing gear running at an angle across the front of block.... Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 3, 2010 Share Posted January 3, 2010 big heavy 2ltr cast straight 4 with timing gear running at an angle across the front of block.... Like this one? Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted January 4, 2010 Author Share Posted January 4, 2010 Like this one? Just like that but without radiator and other bits mine had a 55 mm hole in middle....... Quote Link to comment Share on other sites More sharing options...
Craftycrofty Posted January 4, 2010 Author Share Posted January 4, 2010 The crossmember cones have rusted away can i get replacements or is it a new crossmember.How do you add photos?? Quote Link to comment Share on other sites More sharing options...
keith1200 Posted January 4, 2010 Share Posted January 4, 2010 Your trying to upload it from you desktop! that's how it's not working! but dinna worry (we're a helpful bunch) http://photobucket.com/ Sign up here! then upload pictures (for us to drool on) copy bottom link (of picture) and post it on here GL Keith Quote Link to comment Share on other sites More sharing options...
simon p Posted January 4, 2010 Share Posted January 4, 2010 Stitch weld ARB mounts to chassis rails. Top idea! Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 5, 2010 Share Posted January 5, 2010 The crossmember cones have rusted away can i get replacements or is it a new crossmember.How do you add photos?? I think I can get them but not doing an order anytime soon. There is a workaround in the Kadett thread in my signature Quote Link to comment Share on other sites More sharing options...
vauxsenb Posted January 7, 2010 Share Posted January 7, 2010 (edited) Nope, cant get it to work, have you got a photobucket account (or similer) its free to use and you post the direct link on here and vioala it appears on your post. Cheers Colin. Edited January 7, 2010 by vauxsenb Quote Link to comment Share on other sites More sharing options...
