Best Way To Repair Dropped Door Hinges
Paul Barrett
AndyC on here can get you new genuine door pins, you need to take the old ones out with a special tool, I suspect with a name like novashed you know about old GM doors pins though.
soak the beggers in wd40 or plusgas for a while though, if you are lucky yours will still have the little plastic caps shoved up both ends of each roll pin. that helps keep the grot at bay and makes removal easier.
