Manifold Manufacturer?
manta3000
has anyone had a manifold made or recommend anyone,24v in my manta,but the manifold is a bit rough,as in bits cut here and there to avoid s/rack.
could remove maifold so it could be made properly, using it as template
cheers colin
flat oot or bale oot
cheers colin
Have you tried getting an off the shelf item from Risse Motorsport or maybe Lahouter Motorsport. Only place i've found that can manufacture decent manifolds that will actually increase power is Tony Law but look to pay 400-500 quid for a manifold, also he will want the car with the engine in situ. If anyone knows of anywhere else that can do decent manifolds (apart from ashley, janspeed,etc)then i'd be interested to know. Need to have a big bore one made for the 2.3 and 2.5 motors.
HTH
Chris
have had a look around the web,emailed a few companies
aas-exhausts.co.uk ,there in newcastle look promising
there are others
they will hopefully do manifold from the one i send down,and not need the car
bogg bros. made me a manifold for bike carbs , turned out very nice , cost about £160 i think .
http://www.boggbros.co.uk/index.html
dont do car manifolds only bikes
cheers
You could try Tony Law who are in Leeds
All they do is make custom manifolds and exhausts, usually they make them on the car for the best fit.
Especially useful if you have a race or rally car and need the clearance.
Worth an ask if they can make one from your exisiting template
They're not the cheapest people around, but its a very good service.
I had an exhaust system from them in the past and was very happy with the quality.
