xtcvampire Posted March 24, 2010 Share Posted March 24, 2010 Hello. I just got a pair of Girling Volvo 4 pot calipers for vented discs. Can someone please help me (with pics or detailed info) on how to adapt the brake lines from a manta b to the calipers? Thanks in advance. Greetings from Romania. Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted March 24, 2010 Share Posted March 24, 2010 4 pots on a Manta..dead easy... 1...get some 4 pots from a dead 240 etc volvo with vented discs. 2... get a pair of sierra xr4x4 discs, and have your local enginerring shop drill them to the Manta disc pattern. 3..treat the 4 pots to a new seal kit and some paint.( your life is worth £40!! ) 4.. have some pipes made up to join the 2 inward fluid unions to one. Mk 1 cavalier goodridge hoses have 2 male ends, or mk2 escort. 5.. fit the discs and 4 pots, use mk1 cavalier bolts to fit calipers ( available from vauxhall at about £2 each) 6.. space the calipers so that they are central using a couple of washers. Bleed the 4 pots and there you go. Kev Quote Link to comment Share on other sites More sharing options...
fjz400 Posted March 25, 2010 Share Posted March 25, 2010 You can also use mk1 pug 206 front hoses I did have a pair but binned them as I dont run the volvos anymore.. Quote Link to comment Share on other sites More sharing options...
xtcvampire Posted March 26, 2010 Author Share Posted March 26, 2010 (edited) thanks for your info. I'm interested in the 3 way brake union. From what car could I get a union that will fit the vauxhall/opel brake line? Does anyone know the volvo 240 and the opel brake lines thread? Edited March 26, 2010 by xtcvampire Quote Link to comment Share on other sites More sharing options...
IanMc Posted March 26, 2010 Share Posted March 26, 2010 You can make up a 3 way union/splitter with off the shelf parts from your local motor factor - easy peasy! Get yourself a brake pipe flaring tool, some copper pipe and a bag of fitting a make 'em yourself. I did my whole Cav last Summer for £25 for everything - strangely satisfying as well Quote Link to comment Share on other sites More sharing options...
