Hissing Brake Pedal?
Mrbus
For some reason my brake pedal "hisses" & stops when i press it. Im guessing it is something to do with pressure. I think my brakes work fine & im sure it didnt make that noise before.
Any advice on if it should be like that, or is something wrong? Its a manta B GTE/E.
Might also sell but not sure how much its worth?
1987 GTE/E hatch 107k
MOT sep10
Air is supposed to enter the servo via the area around the brake pedal as it has a foam filter around the pedal rod
If air couldn't get into the servo it would not work, think about it the pipe into the inlet manifold should have a one way valve in so no air flows back in up the vacuum pipe and into the manifold and these only work by allowing air in to press on one side of the diaphragm and move towards the low pressure engine side.
I've had some you can here and some you can't.
vacuum is always applied to both sides of the servo under normal driving conditions. When you brake air is admitted to the "pedal side" through the foam filter so that the vacuum pulls the brakes on. If its hissing its the air admittance valve leaking slightly
So what exactly is the part i need to change? The brakes seem fine when i keep my foot on the pedal as it does not gradually sink to the floor, so im guessing they are fine. I just get the hissing noise when the pedal is not pressed!
You don't "need" to change anything. Your brakes will still work normally, the master cylinder return spring will be enough to prevent the leak from actually pulling the brakes on. If you wanted to get rid of the hiss then you'd be best to change the whole servo unit as I've no idea how to get the valve out, never done it! As a quick check, its worth making sure that the brake light switch isn 't stopping the pedal from fully returning, as this could cause it to leave the valve very slightly open and cause the hiss.
Nothing to panic about in any case though
