shooie811 Posted July 20, 2010 Share Posted July 20, 2010 hi am a bit confused on wats wrong with my cav i recently pickd up 2 original wings off a gte because the ones on the cav were rusted to hell and one of them seemed to be considerably wider than the other which i just fought was due to being a cheap after market one but when i put the 2 gte wings on. the passenger side is wider than the other can anybody help is it maybe due 2 different hubs??? cheeers Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted July 20, 2010 Share Posted July 20, 2010 What do you mean by wider? Is it a wider wheel arch? If so you might have picked up a 400 style front wing, otherwise all front wings should be more or less the same shape, the hubs were all the same right the way through the Cav/Manta range with the exception of the 400s. Any pictures? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted July 20, 2010 Share Posted July 20, 2010 Check wheel offset if necessery try on opposite sides but most likely........... measure your diagonals Quote Link to comment Share on other sites More sharing options...
shooie811 Posted July 20, 2010 Author Share Posted July 20, 2010 forgot 2 mentioned the cars been lowered about 80mm which hightlights that one wheel sits futher in than the other i havnt got a clue why its like that both the wings r exacly the same maybe its been in a smash before??al try post a pic if somone can explain 2 me how to do it lol iam hopeless with computers. cheers Quote Link to comment Share on other sites More sharing options...
mantadoc Posted July 20, 2010 Share Posted July 20, 2010 Check your diagonals to check the engine bay is square Quote Link to comment Share on other sites More sharing options...
pat Posted July 20, 2010 Share Posted July 20, 2010 are we talking the wing being wider on one side or the wheel projecting further on one side & if so is it on the front or rear as if lowered by any amount the panhard rod on the rear axle pushes the axle over , but lowering will not affect the front ends offset Quote Link to comment Share on other sites More sharing options...
keith1200 Posted July 20, 2010 Share Posted July 20, 2010 If it's only out by 2 or 3 mm's then you'll probably have to slack-off all the bolts and adjust the wing. If it's out by 1 cm or more! hmmm Some the club guru's will be able to give you good advice once you post-up picture's. Quote Link to comment Share on other sites More sharing options...
shooie811 Posted July 21, 2010 Author Share Posted July 21, 2010 turns out it was a broken spring and it was accually sitting lower on one side making the wing look wider because the wheel was being coverd by the arch more thanx anyhow. cheers Quote Link to comment Share on other sites More sharing options...
