Scribe of Lincoln Posted September 26, 2010 Share Posted September 26, 2010 Morning, Following last night's meeting with the AA, does anybody have a condenser for a Delco Remy Distributor for an early Manta B 1600 they would like to part with. This is the type that sits in the top of the distributor underneath the dizzy cap, is secured by one screw and has a single wire with a connector on the end,not the Bosch type that clips on the side. Location - Lincoln. Cheers. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted September 26, 2010 Share Posted September 26, 2010 Morning, Following last night's meeting with the AA, does anybody have a condenser for a Delco Remy Distributor for an early Manta B 1600 they would like to part with. This is the type that sits in the top of the distributor underneath the dizzy cap, is secured by one screw and has a single wire with a connector on the end,not the Bosch type that clips on the side. Location - Lincoln. Cheers. You are looking for 3474521 Link to comment Share on other sites More sharing options...
keith1200 Posted September 26, 2010 Share Posted September 26, 2010 Search ebay, they're normally available for £3-£4 pounds. Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted September 26, 2010 Author Share Posted September 26, 2010 Search ebay, they're normally available for £3-£4 pounds. Had a look on there already and they all appear to be for the Bosch distributor. Thanks anyway. Link to comment Share on other sites More sharing options...
Mick Posted September 26, 2010 Share Posted September 26, 2010 AC Delco Condensor on Ebay 75-81 1600... any good to you? Clicky Thingy Link to comment Share on other sites More sharing options...
mantadoc Posted September 26, 2010 Share Posted September 26, 2010 The coils are the same, the voltage is the same, maximum RPM is the same, point are made of vaguely the same material. Doesn't matter if the capacitor lives inside or outside the dizzy just as long as it is from the points wire to earth. I've quite often used the bosch type ones on Em's Kadett on the outside of the Delco Remy when stuck. Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted September 26, 2010 Author Share Posted September 26, 2010 AC Delco Condensor on Ebay 75-81 1600... any good to you? Clicky Thingy Just ordered one from here. Cheers Mick Link to comment Share on other sites More sharing options...
