Track Manta - Camber, Castor Etc
dtm
Hi Guys,
I would like to know what settings you guys have for track cars.
Im talking about camber, castor and toe.
I know its difficult to change these setting in a manta (involving cutting and welding of suspension arms) but im going to do it as my redtop manta is only for track.
Plus would you guys have an idea how to modify the suspension arms so that i can have adjustable castor?
Many thanks guys
dtm
Are you running power steering? Makes a big difference if you are going to increase castor by any great degree? The quick fix for castor is to cut back the front tube where the upper wishbone is connected to the cross member. You can then slide the upper wishbone back and make up the gap with washers at the rear mount. This allows you to adjust the castor back and forth.Camber can be adjusted buy reversing the upper ball joint, or if you require more you can slot the mounting holes and push the ball joint further back.
As a rough set we use 2.3 deg caster ( Non Power steering ) , 2 deg camber and front track at zero. However if you are still using poly or rubber bottom bushes then you may need slight toe in.
I run a corsa type electric power steering on mine so I use a lot more castor.
Hope this is a good starting point for you? :thumbup
thanks for the reply.
sounds interesting!
im not running power steering.
the caster and camber sound about inline with what im reading alright.
is there 0 degrees caster on a standard manta?
i have read that a tiny bit of toe out is good for the manta as it make it more lively to turn into corners a little quicker?
maybe not?!
Sorry for the hijack...
As a matter of interest what castor do you run with the Corsa power steering, as this is the setup I will be using on my Ascona.
I`m using between 7.5 deg to 9 deg castor, but my wishbones are rosejointed inner and outer so I can move them through different plains to the standard type. I always start with zero toe at first until I find what the car is doing, depending on anti-roll bar settings, toe out does work well. :)
thanks guys.
would you have any information/pictures re what size rosejoints you have used and how did you cut the suspension arms and weld the rose joint brackets into place?
this stuff is getting interesting!:thumbup
If it were me, I'd use 5/8" thread by 1/2" hole joints and drill the holes in the x member out from 12mm to half inch. Those joints are prob a tad overkill but better that way than have one snap on you, plus the lower ones take some nasty bending loads from the spring
Ps also use top quality joints with 4130 body and 52100 ball, not mild steel rubbish
I have not done this on a manta so I would be guided by spewy555 but you could do it either way, but would be a lot easier to machine blocks to screw the joints into and weld them into the STD, cut down wishbone. I would make a basic jig so they came out the same length. Arms would want boxing in as well to better retain the blocks
You can have a practice run on mine :rolleyes:
I'm guessing only the upper wish bones would need this doing to make the suspension fully adjustable - something I've been thinking about doing for a while, might be interested in a set if you are contemplating fabricating some, certainly trust some made from your jig rather than one I'd put together.
As a matter of interest, the works cars only rose jointed the top arms, however bottom arms were modified. There is a note of caution for those who use their cars for normal road use as well.
1. Rose joints/ bearings will wear very quickly if not cleaned and maintained constantly.
2. You will bend the upper wishbone bolt very easily as there is no give whatsoever in rose joints.
3. Every fault in the rest of your suspension will become very obvious!
Having said all that if it`s track use get stuck in :thumbup I have got jigs for upper and lower arms but as Retro Power says they are easy enough to make if you have a welder.
thanks for the replies lads.
I really think there is oppertunity here for one of you guys (either retro or spewey) to run a small scale batch of adjustable arms for the manta b.
Maybe you could do them on an exchange basis?
I would definately be interested in this - maybe something to look into?
i would love to see a pic of that jig speewyor even one of your top/bottom suspension arm in the rally car :thumbup
