madmantamik Posted May 29, 2011 Share Posted May 29, 2011 hi all, i came to refit my tank and fuel pump today and i seem to have misplaced (lost) the 13mm rubber hose from the tank to the fuel pump , does any body have one lying around Link to comment Share on other sites More sharing options...
mickappy Posted May 29, 2011 Share Posted May 29, 2011 most car shops do it in metre lenths, Link to comment Share on other sites More sharing options...
madmantamik Posted May 29, 2011 Author Share Posted May 29, 2011 i dont think a straight length will do the job , i seem to remember the original had a tight 90 degree bend as space is tight between the bottom of the tank and the boot floor. Link to comment Share on other sites More sharing options...
garymanc Posted May 29, 2011 Share Posted May 29, 2011 did mine with a straight piece off pipe,it not to bad to do if you unbolt the fuel tank ps hows your car going on mate Link to comment Share on other sites More sharing options...
madmantamik Posted May 29, 2011 Author Share Posted May 29, 2011 its going slowly i really need to stop changing my mind and just get it done. Link to comment Share on other sites More sharing options...
mantadoc Posted May 29, 2011 Share Posted May 29, 2011 You can buy it from the dealers. A 1m length will do two cars and with a lazy curve and no kinks is fine. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted May 30, 2011 Share Posted May 30, 2011 I believe that it is 12mm Link to comment Share on other sites More sharing options...
cam.in.head Posted May 30, 2011 Share Posted May 30, 2011 how about adding an internal spring inside the pipe to re-inforce the bend Link to comment Share on other sites More sharing options...
