wicked999 Posted June 4, 2012 Share Posted June 4, 2012 how to stop axle tramp ive got a mk1 cavalier with a redtop in and i cant stop the axle tramp when giving it the large round town can some one please help thanks matt Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted June 4, 2012 Share Posted June 4, 2012 Decent shockers will sort it Quote Link to comment Share on other sites More sharing options...
rutts Posted June 4, 2012 Share Posted June 4, 2012 and a good set of poly bushes in rear trailing arms. Quote Link to comment Share on other sites More sharing options...
rayman Posted June 4, 2012 Share Posted June 4, 2012 Or cheaper...... a block off wood under accelerator pedal Quote Link to comment Share on other sites More sharing options...
wicked999 Posted June 4, 2012 Author Share Posted June 4, 2012 what sort of shocks stiffer ones ? any make? Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted June 4, 2012 Share Posted June 4, 2012 Billys Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted June 6, 2012 Share Posted June 6, 2012 The main prob with the manta axle is the bearing mount at the front of the torque tube. The "rally" fix was to make a steel strap plate to go over the bearing and then fill the gaps in the mounting bush with silicone sealant. Most of the rear bushes ive seen on older cars are not in bad nick usually but a change to poly bushes will improve things. HTH Chris Quote Link to comment Share on other sites More sharing options...
wicked999 Posted June 7, 2012 Author Share Posted June 7, 2012 thanks i wil have a look at that Quote Link to comment Share on other sites More sharing options...
opel2000 Posted June 14, 2012 Share Posted June 14, 2012 Failing all that............ NOT so large around town always helps followed by correct spring rates and decent shocks. Can't remember the correct spring rates for the Manta but too low and hard on the back is not good, been there myself. Quote Link to comment Share on other sites More sharing options...
