biffy1984 Posted July 22, 2012 Share Posted July 22, 2012 I have Volvo 4 pots on the front of my car. The discs are pretty badly warped now and have been skimmed before so it's probably time to splash out on a new set. My discs fit the caliper perfectly, I was told they were custom made so you don't get the pads overhanging the disc like the Carlton ones. Question is if I'm ordering a set of Carlton ones what year of car are they from? Diameter and thickness of disc etc? And where is a good place to get them from? Might of even tried grooved or drilled if they weren't too overpriced. Thanks. Quote Link to comment Share on other sites More sharing options...
jasonj Posted July 23, 2012 Share Posted July 23, 2012 The discs are 246 x 20mm and are from a Mk1 Carlton up to 1986. I'm not sure if any manufacturers make a drilled or grooved disc in that fitment Quote Link to comment Share on other sites More sharing options...
Roy Posted August 2, 2012 Share Posted August 2, 2012 Black Diamond list them for the 2.2 1986 Carlton. Got them fitted to my B. Vented, drilled and slotted and in sexy black! Part number on the box. Quote Link to comment Share on other sites More sharing options...
opelscott22 Posted August 7, 2012 Share Posted August 7, 2012 Hi Roy, thanks for posting the picture up, what calipers are they? Where did you source them from as I could do with a new pair for my own car. Sorry if Im wrong here but I really hope thats not copper grease on the stub axle as thats really not a good idea for wheel bearings, too low a melting point and doesnt have the same lubrication properties as its meant as an anti seize agent. Scott. Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted August 7, 2012 Author Share Posted August 7, 2012 Thanks Roy, just what I'm looking for. I see Larkspeed have the Black Diamond discs listed for £131 so I'll definately be ordering a set. The wife is very good at warping standard discs and I'm fed up having them skimmed! Cheers Peter Quote Link to comment Share on other sites More sharing options...
Roy Posted August 8, 2012 Share Posted August 8, 2012 Hi Scott, no definitely not copper grease, its the original grease old and dark brown. It was all repacked with new LM grease! The discs look great through the alloys, always gets a comment at the mot Quote Link to comment Share on other sites More sharing options...
opelscott22 Posted August 9, 2012 Share Posted August 9, 2012 Ah ok, Id hate to see you have a bearing collapse on you! (been there, not fun) Can you tell me what the calipers are? I think I can use Mk2 Astra GTE ones but not quite sure. Those discs do look nice though, Ill have to get myself a pair of those for stock! Thanks, Scott. Quote Link to comment Share on other sites More sharing options...
Shug Posted August 9, 2012 Share Posted August 9, 2012 Carlton calipers are listed on brakeparts.co.uk for around 50 quid each. Quote Link to comment Share on other sites More sharing options...
