Manta B, Ascona B And Manta A Panels Back In Stock With Prices!
Retro Power
Now in stock, the following panels! All prices include VAT.
Postage is £9 for the smaller items, £12 for the larger, and if ordering multiple panels, each additional is £1 post.
Paypal to 'paypal@retropower.co.uk'
Nova 3 door full outer sill £12
Nova 3 door Left Arch £11
Nova 3 door Right £11
Kadett c & Chevette 2 door left sill
kadett c 2 & Chevette 2 door right sill
kadett c & Chevette roof pillar repair £45
kadett c & Chevette arch repair left £33
kadett c & Chevette arch repair right £33
kadett c & Chevette floor repair Left £28
kadett c & Chevette floor repair Right £28
mk1 astra full sill 2 door £15
mk1 astra left inner arch repair £39
mk1 astra right inner arch repair £39
mk1astra rear panel(lower) £15 manta a left inner wing reinforcer £19
manta a right inner wing reinforcer £19
manta a right rear corner £25
manta a left rear corner £25
manta a lower rear panel £44
ascona b and manta b 2 door right full sill £21
ascona b and manta b 2 door left full sill £21
manta b front panel £48
manta b front valance £53
manta b left arch repair £21
manta b right arch repair £21
ascona b 4 door left full sill £22
ascona b 4 door right full sill £22
ascona b headlamp surround £11
ascona b & manta b spare wheel well £35
ascona b and manta b front bump stop carrier £32
ascona b 4 door left arch £18
ascona b 4 door right arch £18
ascona b 2 door right arch £28
ascona b 2 door left arch £28
ascona b and manta b left jacking point £26
ascona b and manta b right jacking point £26
ascona b and manta b axle spring pan left £44
ascona b and manta b axle spring pan right £44
ascona b and manta b rear spring seat/chassis rail section £29
Photos here:http://s845.beta.pho.../library/panels
As well as that lot we are also offering 'a' panel/footwell side repair sections. These replace the whole panel forward of the door hinge pillar, and is probably one of the most common manta rot areas.
These are £65 per side inc. VAT.
Edited by Retro Power
listed parts for better reading
il take the ascona 4 door rear wheel arch,left and right please.just pm me your paypal details,cost and when you want the cash.
cheers
Rab
In theory, yes. however i know last time i could only get r/h, so although i apparently have l/h on this order i won't make promises until i have actually seen them!
£18.00 per side inc. VAT
yes, manta B wheel well same
Yep, £35 inc. VAT.
Do you mean that same as the ascona wheel well?
Very interested.
Any chance of a picture? Just want to see the profile and how much of the metal surrounding the bowl is included with the panel. Does the panel have a drain plug hole?
yes, sorry, typing too quick!! manta and ascona spare wheel wells are the same. The wheel well panel is a replacment for the entire original panel (if you look, there is a seam at the bottom of the inner edge, it is not originally part of the boot floor pressing. It has the depression where the hole goes, but you will need to cut the hole out
I'll get photos as soon as they arrive.
Cheers,
Callum.
Do you have any Manta B Bump Stop carriers (the bit that the rubber bump stop pushes into that sits within the front springs) please? If so can you advise how much?
Many thanks.
I will have one pair on the delivery - I'm afraid they are disproportionally expensive to their size, at £31 each. If you take the pair i'll do you the post for free though as a one-off ;-)
Posted 26 October 2012 - 07:05 PM
snapback.pngRetro Power, on 25 October 2012 - 07:44 AM, said:
Thanks - i try to keep the prices as reasonable as possible. Manta sills for instance are £21 per side, as are arches (inc. VAT)
If these are for Manta B then can I put my name on a pair of sills and a pair of arch repair panels.
Thanks. Andrew
PM sent regarding these bits.
CHEERS!
Edited by Andrew65
Got your HUGE parcel today with the sills and arches.
Is there any brown tape left in Leicester??
Decided I might as well get these as well.
Please let me know the total and I'll send the Paypal.
Thanks. Andrew
Thanks. Andrew
