eurocamper1 Posted November 30, 2012 Share Posted November 30, 2012 Hello greetings from Denmark Im new hear and new to the manta B When it rains and have a puddle water in my coupe trunk has anybody else had this problem and how too cure it previous owner has not used the rubber window seal but glued the window in it all looks good with no holes the water could leak in from and 2 my heater is leaking in rain water I tested it by covering the heater intake vent near the windsheild and the leaking went away drain probably clogged my question is about how to take it apart do i start from the engine compartment or from the interior and take out dash Thanks Henrik Quote Link to comment Share on other sites More sharing options...
garymanc Posted November 30, 2012 Share Posted November 30, 2012 hi henrik to remove the plastic from near the heater vent is all undone from the engine compartment and have you tried a new boot seal to stop water going into the boot or try some non hardening sealer around the rear screen like this http://www.ebay.co.uk/itm/290484791899 in the mean time till you stop the leaks just dry the water away daily with a towel ,done it myself for years Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted December 1, 2012 Share Posted December 1, 2012 When you remove the plastic heater parts, they are screwed down from the engine bay into the interior of the car. If those screw holes haven't been sealed then water will get in. Water also finds its way in via the bonnet pull cable. In the boot, make sure the rear lights are tight to the body and sealed. Try a new boot seal. I used a mondeo mk1 hatch seal and cut it to size. Much better as it has 2 sealing surfaces. Water can also get in via the fuel filler hole and if the drains from the sunroof have moved you may be filling your boot via your roof :-) Quote Link to comment Share on other sites More sharing options...
Robert1234 Posted December 11, 2012 Share Posted December 11, 2012 (edited) If it's a sunroof model then the water in the "trunk" could be the drain pipes, remove the piece of card at the back of the trunk and there will be some pipes for the sunroof, or they may be infront of it I cant really remember. Edited December 11, 2012 by Robert1234 Quote Link to comment Share on other sites More sharing options...
